Problem with parameterized types
I try to compile this code :
type mytype(klon,klev)
  integer, len :: klon=1, klev=1
  real a(klon,klev)
end type
integer :: kklon, kklev
character*32 :: clarg
call getarg (1, clarg); read (clarg, *) kklon
call getarg (2, clarg); read (clarg, *) kklev
call toto (kklon, kklev)
contains
subroutine toto (kklon, kklev)
type (mytype (kklon, kklev)) :: x
print '("Component of x has size ", I0)', SIZE(x%a)
end subroutine
end
But I get :
[CNC tmp]$ pgf90 --version
pgf90 (aka nvfortran) 21.5-0 LLVM 64-bit target on x86-64 Linux -tp zen
PGI Compilers and Tools
Copyright (c) 2021, NVIDIA CORPORATION.  All rights reserved.
[CNC tmp]$ pgf90 -o ss.x ss.F90
NVFORTRAN-F-0000-Internal compiler error. mk_mem_ptr_shape: lwb not subs      11  (ss.F90: 25)
NVFORTRAN/x86-64 Linux 21.5-0: compilation aborted
Are parameterized types supported by pgf90/nvfortran ?
Regards,
Philippe
Hi Philippe,
Yes, though it looks like we have issue with this code. I filed a problem report, TPR #30383, and sent it to engineering.
Nvfortran is having trouble referencing the parameterized derived type (PDT) “mytype” in the internal procedure, toto. It will compile/run successfully if the mytype definition is moved into the toto internal procedure. However, this may not be a viable work around if x in toto has to be returned to the caller.
For example, this will work:
        program main
       type :: mytype(klon,klev)
          real :: a(klon,klev)
       end type mytype
       contains
       end type mytype
           type (mytype(kklon, kklev)) :: x
       end subroutine toto
       end
Another possible work around that avoids the problem if you need to return x to the caller is to use a module for the PDT and the toto subprogram:
      module mod
       end type mytype
       contains
       end subroutine toto
       end module
        program main
        use mod
       end
-Mat
Thank you Mats for your advice.
Another thing which seems to be broken :
$ cat main.F90
module mod
type :: mytype(klon,klev1,klev2)
    integer, len :: klon=1, klev1=1, klev2=1
    real :: a(klon,klev1:klev2)
end type mytype
contains
    type (mytype(kklon, 0, kklev)) :: x
end subroutine toto
end module
 program main
 use mod
end
$ gfortran main.F90
$ ./a.out 12 34
Component of x has size 420
$ pgf90 main.F90
$ ./a.out 12 34
Component of x has size 408
$ pgf90 --version
pgf90 (aka nvfortran) 21.5-0 LLVM 64-bit target on x86-64 Linux -tp skylake
Philippe
While probably related, this issue is different enough that I created a separate issue report, TPR #30389.
What’s interesting is that it seems that the problem only occurs if the lower bound is zero. Using a negative or positive lbound seems to work ok.
% cat test.f90
#ifndef LBOUND
#define LBOUND 1
#endif
module mod
end type mytype
contains
    integer :: kklon, kklev,i,j
    type (mytype(kklon, LBOUND, kklev)) :: x
    do i=1,kklon
        do j=LBOUND,kklev
           x%a(i,j) = 1.0
        enddo
    enddo
    print *, x%a(:,LBOUND)
end subroutine toto
end module
 program main
 use mod
end
% nvfortran test.f90 -Mpreprocess -DLBOUND=1 ; a.out 12 34
    1.000000        1.000000        1.000000        1.000000
% nvfortran test.f90 -Mpreprocess -DLBOUND=0 ; a.out 12 34
Segmentation fault
% nvfortran test.f90 -Mpreprocess -DLBOUND=-1 ; a.out 12 34
Component of x has size 432
% nvfortran test.f90 -Mpreprocess -DLBOUND=-2 ; a.out 12 34
Component of x has size 444
% nvfortran test.f90 -Mpreprocess -DLBOUND=2 ; a.out 12 34
Component of x has size 396
Hi Phillipe,
FYI, the second issue, TPR #30389, has been resolved in our 22.9 release.
% pgf90 main.f90 -V22.7; a.out 12 34
% pgf90 main.f90 -V22.9 ; a.out 12 34
-Mat
