Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
[yes] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
Host Machine Version
[yes] native Ubuntu 18.04
other
Recently, I test the performance of Xavier. I transform a model into igpu, dla0 and dla1.
cost time as following:
igpu1: 105000ms
igpu2: 183000ms
igpu4: 350000ms
dla0: 245000ms
igpu1+dla0:324000ms
igpu*2+dla0+dla1: 355000ms
So, firstly, the dla is slower than igpu very much.
Secondly, when I use igpu and dla together for two thread, I need more time than just using igpu.
The layers of my model can not all run in dla, some layers need to fallback to gpu which will affect igpu seriously?
Dear @wang_chen2,
iGPU has more DL Tops(perf) than DLA. We geberally notice iGPU takes less time compared to DLA.
When gpufall is enabled, the layers that can’t run on DLA will move back to iGPU. This involves an additional data transfer of intermidiate layer output which causes increase in overall execution time.
Hi,@SivaRamaKrishnaNV
So, the my cost time is reasonable?
In best case, using dla will not affect igpu?
Are there some suggests for using dla to improve performance?
DLA is designed for low power rather than performance.
Usually, we recommend DLA when users want to release GPU or increase throughput.
Not sure if I understand your benchmark result correctly.
When you running GPU along with DLA, you should get 2x throughput although the latency increases.
More, could you try to set the below environment variable to see if it helps?
$ export CUDA_DEVICE_MAX_CONNECTIONS=32
You can find more details about this variable in the below topic:
