Has anyone ever tested the compression ratio of nvenc? I tried to test the performance of NVEnc using rigaya/NVEnc. Below is the download address of rigaya/NVEnc.
I tested hevc and h264. But the pompression ratio of hevc was lower than that of h264. It is quite strange.
NVEncC64.exe --input-res 3840x2160 --fps 30 --raw --input-csp yuv420p -i D:\Test\asia.yuv -c hevc --cqp 26:26:26 -u performance -b 0 --gop-len 256 --mv-precision Q-pel --tier high -o D:\asia.h265
D:\asia.h265
NVEncC (x64) 5.46 (r2126) by rigaya, Mar 5 2022 12:31:25 (VC 1929/Win)
OS Version Windows Server 2016 x64 (17763) [CP936]
CPU Intel Xeon(R) Platinum 8163 @ 2.50GHz [TB: 2.70GHz] (5C/10T)
GPU #0: GRID T4-8Q (2560 cores, 1590 MHz)[2147483.64]
NVENC / CUDA NVENC API 9.0, CUDA 10.1, schedule mode: auto
Input Buffers CUDA, 13 frames
Input Info raw(yv12)->nv12 [AVX2], 3840x2160, 30/1 fps
Vpp Filters copyHtoD
Output Info H.265/HEVC main @ Level auto
3840x2160p 1:1 30.000fps (30/1fps)
Encoder Preset performance
Rate Control CQP I:26 P:26 B:26
Lookahead off
GOP length 256 frames
B frames 0 frames [ref mode: disabled]
Ref frames 3 frames
AQ off
CU max / min auto / auto
Others mv:Q-pel
encoded 1388 frames, 11.69 fps, 9753.77 kbps, 53.80 MB
encode time 0:01:58, CPU: 1.0%, GPU: 3.5%, VE: 5.5%
frame type IDR 6
frame type I 6, total size 3.01 MB
frame type P 1382, total size 50.78 MB
NVEncC64.exe --input-res 3840x2160 --fps 30 --raw --input-csp yuv420p -i D:\Test\asia.yuv -c h264 --cqp 26:26:26 -u performance -b 0 --gop-len 256 --mv-precision Q-pel --tier high -o D:\asia.h264
D:\asia.h264
CPU Intel Xeon(R) Platinum 8163 @ 2.50GHz [TB: 2.71GHz] (5C/10T)
Output Info H.264/AVC high @ Level auto
Lookahead off
Ref frames 3 frames
AQ off
Others mv:Q-pel cabac deblock adapt-transform:auto
encoded 1388 frames, 153.66 fps, 7984.46 kbps, 44.04 MB
encode time 0:00:09, CPU: 11.7%, GPU: 54.5%, VE: 99.0%
frame type IDR 6
frame type I 6, total size 3.24 MB
frame type P 1382, total size 40.80 MB
