This is probably the wrong forum, but I couldn’t find a better one.
PIX is giving me the following error in the timeline window: This feature is unavailable because the GPU Plugin failed to initialize. See the Warnings view or Output view for more details.
The output view contains the following log message: PU Plugin initialization failed: 0x81dd0100 () - This hardware configuration is unsupported by Perfworks. If you are using SLI, please disable this feature to enable Perfworks support.
I am not using SLI. I’ve got a RTX 2080 Super. I’ve selected “Allow access to GPU performance counters for all users” in the NVidia Control panel.
I’m aware that PIX is a Microsoft tool but the Perfworks plugin is from NVidia, isn’t it? I doubt that Microsoft will be able to help me with the plugin, or will they?
It says, that PerfWorks has been replaced by NSight Perf SDK, so I think this is the right forum since there is no forum for PerfWorks
Just to follow up to see if you have contacted and got any feedback from Microsoft on this issue. I also wanted to confirm that RTX 2080 is supported by the Nsight Perf SDK used by PIX.
