Hi everyone,
I am trying to enable a MTU of 9000 on our Jetson Nano (JP 4.5.1). I can do so with:
“ifconfig eth0 mtu 9000”
However this is not kept after a reboot.
I can permanently set the MTU via the desktop environment, this is reboot save.
Is there a way to set the MTU permanently via the terminal?
I have already tried:
" sudo ifconfig eth0 down && sudo ifconfig eth0 mtu 1500 && sudo ifconfig eth0 up"
Thanks for your help.
Can I provide more information, to solve this issue?
Greetings
I don’t know myself, but the topic is probably specific to Ubuntu 18.04 (which is what that JetPack release installs). I found this Google search was of interest, although I don’t know if it actually works:
https://askubuntu.com/questions/1127497/how-can-i-change-mtu-size-permanently
One of the problems is that I don’t know which releases use NetworkManager versus other software. However, if it is NetworkManager, then the GUI app “nm-connection-editor
” (plus the built in GUI config tools) have an MTU setting (if you don’t have “nm-connection-editor
”, then “sudo apt-get install network-manager-gnome
Any Ubuntu 18.04 documentation probably applies.
system
Closed
July 6, 2022, 2:10am
6
