Hello, I want to use jetson (VNC,ssh) in offline.
So, I considered that there is no problem if PC and jetson are connected by a wired LAN.
But, after I connected them , there is no IP address. ( ifconfig )
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:a7:9b:ba:4e txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:04:4b:e6:60:44 txqueuelen 1000 (Ethernet)
RX packets 5003 bytes 5103015 (5.1 MB)
TX packets 1996 bytes 567913 (567.9 KB)
device interrupt 151 base 0xa000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 1589 bytes 102884 (102.8 KB)
TX packets 1589 bytes 102884 (102.8 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:f2:dc:d1:db:2d txqueuelen 1000 (Ethernet)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:f2:dc:d1:db:2f txqueuelen 1000 (Ethernet)
Please tell me the solution.( ;∀;)
