Disconnected -you are now offline
hi,help someone help me.
i falsh my jetson-nano whit the file from official file : jetson-nano-sf-r32.2-2019-07-16.zip
after i boot my nano , i use the ethernet cable to connect my computer,because i wanna to use SSH to conenct the nano and share the internet with nano.
but i notice the wifi singal (Sector symbol) is always glitter,but i not plug in wifi module.(the symbol used to be Double arrow)
afterwile,it will pop “Disconnected -you are now offline”
for convinent, i use wifi module to connect internet
my ifconfig info:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        ether 00:e0:4c:68:02:16  txqueuelen 1000  (Ethernet)
        RX packets 2295  bytes 287220 (287.2 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 3186  bytes 569723 (569.7 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 149  base 0xb000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 10188  bytes 637146 (637.1 KB)
        TX packets 10188  bytes 637146 (637.1 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b6:66:e1:df:f7:d5  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b6:66:e1:df:f7:d7  txqueuelen 1000  (Ethernet)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.199.171  netmask 255.255.255.0  broadcast 192.168.199.255
        inet6 fe80::7b0d:eb6c:c5d1:d03  prefixlen 64  scopeid 0x20<link>
        ether 08:57:00:bc:70:b1  txqueuelen 1000  (Ethernet)
        RX packets 195  bytes 24979 (24.9 KB)
        TX packets 230  bytes 55401 (55.4 KB)
i wanna use the eth0 through ssh ,but it not display ip? it’s seems the nano can’t distinguish the eth connection.
how can it connect to my compurter?
thanks!
Are you connecting through a router? The default is to use a DHCP server (provided by a router) to get an address. A direct connection (without even a switch) would require (a) a crossover cable, and (b) a DHCP server added to your host PC. If you have a router you just plug both into the same router (or a switch connected to the router) using ordinary cables.
