We’re attempting to help a user compile a code called MET from UCAR. The following errors are seen, which seem to indicate problems in PGI related source, and please feel free to post any thoughts or suggestions:
pgCC -o pb2nc pb2nc.cc pb2nc_Conf.o numpbmsg.o openpb.o readpb.o dumppb.o
-g -Bstatic -DMET_BASE="/wrkdir/user/MET/METv1.0"
-I/usr/local/pkg/gsl/gsl-1.8.gcc/include
-I…/…/lib -I…/…/lib -I/usr/local/pkg/netcdf/netcdf-3.6.1.pgi/include -I/wrkdir/user/MET/BUFRLIB -I/wrkdir/user/MET/F2C
-L…/…/lib -L…/…/lib “-L/usr/local/pkg/netcdf/netcdf-3.6.1.pgi/lib -L/usr/local/pkg/netcdf/netcdf-3.6.1.pgi/include” -L/wrkdir/user/MET/BUFRLIB -L/wrkdir/user/MET/F2C
-lbufr -lvx_grib_classes -lvx_wrfdata -lvx_econfig
-lvx_data_grids -lvx_math -lvx_cal -lvx_util -lvx_met_util -lm -lf2c
-lnetcdf_c++ -lnetcdf -lpgftnrtl -lrt -lpthread
pb2nc.cc:
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 55: error:
the global scope has no “isalnum”
using _STLP_VENDOR_CSTD::isalnum;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 56: error:
the global scope has no “isalpha”
using _STLP_VENDOR_CSTD::isalpha;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 57: error:
the global scope has no “iscntrl”
using _STLP_VENDOR_CSTD::iscntrl;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 58: error:
the global scope has no “isdigit”
using _STLP_VENDOR_CSTD::isdigit;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 59: error:
the global scope has no “isgraph”
using _STLP_VENDOR_CSTD::isgraph;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 60: error:
the global scope has no “islower”
using _STLP_VENDOR_CSTD::islower;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 61: error:
the global scope has no “isprint”
using _STLP_VENDOR_CSTD::isprint;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 62: error:
the global scope has no “ispunct”
using _STLP_VENDOR_CSTD::ispunct;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 63: error:
the global scope has no “isspace”
using _STLP_VENDOR_CSTD::isspace;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 64: error:
the global scope has no “isupper”
using _STLP_VENDOR_CSTD::isupper;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 65: error:
the global scope has no “isxdigit”
using _STLP_VENDOR_CSTD::isxdigit;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 66: error:
the global scope has no “tolower”
using _STLP_VENDOR_CSTD::tolower;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/cctype”, line 67: error:
the global scope has no “toupper”
using _STLP_VENDOR_CSTD::toupper;
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 43: error:
identifier “_ISspace” is undefined
space = _Locale_SPACE,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 44: error:
identifier “_ISprint” is undefined
print = _Locale_PRINT,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 45: error:
identifier “_IScntrl” is undefined
cntrl = _Locale_CNTRL,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 46: error:
identifier “_ISupper” is undefined
upper = _Locale_UPPER,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 47: error:
identifier “_ISlower” is undefined
lower = _Locale_LOWER,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 48: error:
identifier “_ISalpha” is undefined
alpha = _Locale_ALPHA,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 49: error:
identifier “_ISdigit” is undefined
digit = _Locale_DIGIT,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 50: error:
identifier “_ISpunct” is undefined
punct = _Locale_PUNCT,
“/import/local/pkg/pgi/pgi-7.1.6/linux86-64/7.1-6/include/CC/stl/_ctype.h”, line 51: error:
identifier “_ISxdigit” is undefined
xdigit = _Locale_XDIGIT,
“/usr/local/pkg/netcdf/netcdf-3.6.1.pgi/include/ncvalues.h”, line 35: warning:
integer conversion resulted in a change of sign
static const ncbyte ncBad_byte = NC_FILL_BYTE;
“…/…/lib/vx_econfig/symtab.h”, line 210: warning: type qualifier on return
type is meaningless
const SymbolTableEntry * const entry(int) const;
“pb2nc.cc”, line 86: warning: variable “mxstrl” was declared but never
referenced
static const int mxstrl = 80; // Maximum BUFR string length
“pb2nc.cc”, line 96: warning: variable “var_char” was declared but never
referenced
static const char var_char[mxr8vt] = {
22 errors detected in the compilation of “pb2nc.cc”.
make[3]: *** [pb2nc] Error 2
make[2]: *** [all] Error 2
make[1]: *** [targets] Error 2
make: *** [all] Error 2
