I try to use the MPI profiling statistics with pgprof and I’m having no results. I remember that with the cdk 5.2 (received CD), it was ok. Since 6.0, we don’t receive CDK CDs so I try the mpich_kit available on the web site.
My simple MPI_Send-Recv profiled test don’t count bytes and messages.
I’m using -Mprof=mpi,func, it gives a different exec from -Mprof=func (in size)
If the mpich_kit supports mpi profiling, could you give me a example that works?
You do need a CDK license to use the MPI features of PGPROF with or without the MPICH Kit. I wondering if when your upgraded to 6.0 is you kept your CDK license? If you don’t know which license you have, please email trs@pgroup.com with your PGI PIN number and they can help.
I did verify that the Messages and Byte counts are available when compiling with “-Mprof=mpi,func”. However, you do need to select PGPROF’s “View” menu’s options “Message” and “Bytes” to make them visible.
and if I want it profiled, i will add the -Mprof arguments…
pgcc -Mmpi -Mprof=func,mpi
But it seems that -Mmpi is implicit. And if I write it, it don’t profile the mpi calls!!! This is a strange conflicts. It’s not natural to remove argument to add the profiling… and when I use mpicc, it don’t work either.
Me, I’ll never foget it !! but I think you should correct the situation in future version.
For clarification, do you mean that when using “-Mprof=mpi” that “-Mmpi” should be implicit, or do you mean when using “-Mmpi -Mprof” that the “-Mprof” suboption “mpi” should be implicit?
If my situation is ‘normal’… I think that someone who wants to profile the mpi calls should only have to add the the “-Mprof=mpi,func” to the compilation line who already looks like “pgf77 -Mmpi”.
The confusion came from the fact that I forgot to remove -Mmpi.
If we want to compile a profiled MPI program, it’s not trivial that we have to remove de -Mmpi flags…
You might have been confused by original response. I mentioned only “-Mprof=mpi,func” since it works with or without “-Mmpi”. I didn’t intend for you to think that “-Mmpi” needed to be removed. The two flags are not dependent upon each other. All “-Mmpi” does is add the default MPICH libraries at link time which could also be achived by using “mpicc” or adding the MPICH libraries directly on the link line.
I think that the 2 similar systems where I do my testing could have a config problem. But that’s what i got.
pgcc -Mmpi :
MPI only, no profile (ok!)
pgcc -Mmpi -Mprof-mpi,func :
MPI, I can look at the function profile for each process but i don’t see the messages and byte count
pgcc -Mprof-mpi,func
MPI, i can look at the function profile for each process and I see the messages and byte count
(ok)
All I try to explain is, if that behavior is common someone should change it. The command ‘pgcc -Mmpi -Mprof-mpi,func’ and ‘pgcc -Mprof-mpi,func’ should give the same binary.
L-A
this is the different dryrun output (only the diffs):
