I’m trying to run a simple code, from the openacc tutorials, in pgprof in order to analyze the program in terms of computing time.
Although, i get the error “Unable to locate cuda driver library - GPU profiling skipped”. But i double checked the path directory that is being used and its all good, directory is : “/opt/pgi/linux86-64/2017/cuda/9.0/bin/”.
How can i solve this? Does this mean cuda e badly installed?
[edit] If i go to my cuda installation directory “/opt/pgi/linux86-64/2017/cuda/9.0/bin” and run ./nvcc -V i get this:
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
You need to install the CUDA Device Driver in order to run code on your device. “nvcc” is the CUDA compiler driver not to be confused with the device driver.
Starting the Installer
After you have downloaded the file NVIDIA-Linux-x86_64-390.42.run, change to the directory containing the downloaded file, and as the root user run the executable:
cd yourdirectory
sh NVIDIA-Linux-x86_64-390.42.run
The .run file is a self-extracting archive. When executed, it extracts the contents of the archive and runs the contained nvidia-installer utility, which provides an interactive interface to walk you through the installation.
There was a problem with Unified Memory profiling in CUDA 8.0 on some devices, but this should have only given you a warning, not an error. You can try using CUDA 9.0 or 9.1 instead (i.e. use -ta=tesla:cuda9.0, -ta=tesla:cuda9.1, -Mcuda=cuda9.0, or -Mcuda-9.1).
However, since the problem goes away when running as root, it could be a permission problem with the CUDA driver. If so, then I’m not sure how to fix this.
Alternatively, you can try disabling unified memory profiling via the option:
pgprof --unified-memory-profiling=off a.out
I saw that running the profiler with root privileges solves the problem, but when i do “sudo pgprof” i get “pgprof command not found”
I’m assuming when ran as root you set the PATH to include the PGI installation. Using “sudo”, the default root environment will be used and unless you have root’s shell configuration file to include the PGI path, it wont be able to find pgprof.
