I have created a pipeline for object detection and redaction of a certain class of object. I have modified deepstream-imagedata-multistream to do that. I have used filesink as sink element.
Everything works fine if I pass only one input stream. But, if more than one input stream is passed, the pipeline switches to PAUSED state after a few frames.
Environment
• Hardware Platform : GPU
• DeepStream Version : 6
• TensorRT Version : 8.0.1
/home/sandeep/Evaluation/My_Code# python3 main_0.7.py http://commondatastorage.googleapis.com/gtv-videos-bucket/sample/BigBuckBunny.mp4 http://commondatastorage.googleapis.com/gtv-videos-bucket/sample/ElephantsDream.mp4
Unable to init server: Could not connect: Connection refused
cfg_file_name : /home/sandeep/Evaluation/My_Code/dstest_imagedata_config_copy.txt
Creating pipeline
batch_size: 2
Creating Element: nvstreammux
Creating Element: nvinfer
Creating Element: nvvideoconvert
Creating Element: nvdsosd
Creating Element: nvstreamdemux
Writing to existing directory Output_Videos/stream_0
Creating source_bin 0
Creating source bin
bin_name : source-bin-00
Creating sink bin
bin_name : sink-bin-00
Creating Element: x264enc
Creating Element: avimux
Creating Element: filesink
sink_bin.pads : [<Gst.GhostPad object at 0x7f1f2b07f678 (GstGhostPad at 0x303c370)>]
Writing to existing directory Output_Videos/stream_1
Creating source_bin 1
Creating source bin
bin_name : source-bin-01
Creating sink bin
bin_name : sink-bin-01
sink_bin.pads : [<Gst.GhostPad object at 0x7f1f2b07f630 (GstGhostPad at 0x303c870)>]
batch_size : 2
Adding Probe to sink pad
Changing pipeline state to playing
0:00:02.706994875 131 0x304c0f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/sandeep/Evaluation/My_Code/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.707143071 131 0x304c0f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1833> [UID = 1]: Backend has maxBatchSize 1 whereas 2 has been requested
0:00:02.707163132 131 0x304c0f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: deserialized backend context :/home/sandeep/Evaluation/My_Code/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed to match config params, trying rebuild
0:00:02.709758587 131 0x304c0f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:00:15.000231139 131 0x304c0f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /home/sandeep/Evaluation/My_Code/Primary_Detector/resnet10.caffemodel_b2_gpu0_int8.engine successfully
0:00:15.010561670 131 0x304c0f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer> [UID 1]: Load new model:/home/sandeep/Evaluation/My_Code/dstest_imagedata_config_copy.txt sucessfully
Decodebin child added: source
Decodebin child added: typefindelement0
Decodebin child added: typefindelement1
Starting main
Pipeline state changed from NULL to READY
Pipeline state changed from READY to PAUSED
Decodebin child added: decodebin0
Decodebin child added: queue2-0
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: decodebin1
Decodebin child added: queue2-1
Decodebin child added: aacparse0
Decodebin child added: qtdemux1
Decodebin child added: multiqueue1
Decodebin child added: aacparse1
Decodebin child added: avdec_aac0
Decodebin child added: avdec_aac1
Decodebin child added: h264parse0
Decodebin child added: h264parse1
Decodebin child added: capsfilter0
Decodebin child added: capsfilter1
Decodebin child added: nvv4l2decoder0
Decodebin child added: nvv4l2decoder1
Frame Number= 0 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 1 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 2 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 3 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 4 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 5 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 6 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 7 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 8 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 9 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 10 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 11 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 12 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 13 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 14 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 15 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 16 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 17 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 18 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 19 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 20 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 21 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 22 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 23 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 24 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 25 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 26 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 27 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 28 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 29 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 30 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 31 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 32 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 33 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 33 Number of Objects= 1 Vahicle_count= 0 Person_count= 0
Frame Number= 34 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 34 Number of Objects= 1 Vahicle_count= 0 Person_count= 0
Frame Number= 35 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 35 Number of Objects= 2 Vahicle_count= 0 Person_count= 0
Frame Number= 36 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 36 Number of Objects= 2 Vahicle_count= 0 Person_count= 0
Frame Number= 37 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 37 Number of Objects= 1 Vahicle_count= 0 Person_count= 0
Frame Number= 38 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 39 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 40 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 41 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 42 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 43 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 44 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 45 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 46 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 47 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 48 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 49 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 50 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 51 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 52 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 53 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 54 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 55 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 56 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 57 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 58 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 59 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 60 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 61 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 62 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 63 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 64 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Frame Number= 65 Number of Objects= 0 Vahicle_count= 0 Person_count= 0
Please, let me know how I can get out of this.
Thanks in advance.
0:00:16.134562923 676 0x2b84f60 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<filesink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
The entire log is:
/home/sandeep/Evaluation/My_Code# python3 main_0.7.py file:///home/sandeep/Evaluation/My_Code/WeAreGoingOnBullrun.mp4 file:///home/sandeep/Evaluation/My_Code/BigBuckBunny.mp4
Creating pipeline
batch_size: 2
Creating source bin
Creating sink bin
sink_bin.pads : [<Gst.GhostPad object at 0x7f8eeb601798 (GstGhostPad at 0x2b4c370)>]
Creating source bin
Creating sink bin
sink_bin.pads : [<Gst.GhostPad object at 0x7f8eeb601750 (GstGhostPad at 0x2b4c870)>]
batch_size : 2
0:00:02.452108217 766 0x2b5c6f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/sandeep/Evaluation/My_Code/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.452214731 766 0x2b5c6f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1833> [UID = 1]: Backend has maxBatchSize 1 whereas 2 has been requested
0:00:02.452234179 766 0x2b5c6f0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: deserialized backend context :/home/sandeep/Evaluation/My_Code/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed to match config params, trying rebuild
0:00:02.454608769 766 0x2b5c6f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
0:00:14.094762445 766 0x2b5c6f0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /home/sandeep/Evaluation/My_Code/Primary_Detector/resnet10.caffemodel_b2_gpu0_int8.engine successfully
0:00:14.104805117 766 0x2b5c6f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer> [UID 1]: Load new model:/home/sandeep/Evaluation/My_Code/dstest_imagedata_config_copy.txt sucessfully
0:00:14.105895132 766 0x2b5c6f0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:14.107878726 766 0x2b5c6f0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:14.108914055 766 0x2b5c6f0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:14.109794456 766 0x2b5c6f0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
Starting main
0:00:14.124368841 766 0x2a5ce40 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type iods
0:00:14.124371827 766 0x7f8df0078f60 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type iods
0:00:14.124486148 766 0x2a5ce40 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gsst
0:00:14.124511262 766 0x2a5ce40 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gstd
0:00:14.124539805 766 0x7f8df0078f60 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gsst
0:00:14.124543703 766 0x2a5ce40 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gssd
0:00:14.124606491 766 0x7f8df0078f60 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gstd
0:00:14.124653295 766 0x2a5ce40 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gspu
0:00:14.124684576 766 0x7f8df0078f60 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gssd
0:00:14.124710150 766 0x2a5ce40 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gspm
0:00:14.124738677 766 0x7f8df0078f60 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gspu
0:00:14.124762719 766 0x2a5ce40 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gshh
0:00:14.124795688 766 0x7f8df0078f60 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gspm
0:00:14.124847831 766 0x7f8df0078f60 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type gshh
0:00:14.124933143 766 0x2a5ce40 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:14.124964094 766 0x7f8df0078f60 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux1> failed to find fragment defaults for stream 1
0:00:14.125207791 766 0x2a5ce40 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:00:14.125301068 766 0x7f8df0078f60 WARN qtdemux qtdemux.c:3237:qtdemux_parse_trex:<qtdemux1> failed to find fragment defaults for stream 2
0:00:14.195605253 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.195676452 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:14.195699932 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.195720635 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:14.195762833 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.195827886 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:14.195856801 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.195884972 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:14.195926810 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.195947679 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:14.195968055 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.195995055 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:14.196032994 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196074224 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:00:14.196103419 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196123065 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:00:14.196154184 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196175581 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP90
0:00:14.196195028 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196220987 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP90
0:00:14.196254368 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196263579 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP80
0:00:14.196279371 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196287922 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP80
0:00:14.196307261 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196321048 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:00:14.196333850 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:00:14.196342614 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:00:14.196421697 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196505718 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:14.196574789 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196609605 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:14.196664961 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196695533 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:14.196734394 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196761551 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:14.196802363 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196829114 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:14.196856927 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196884512 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:14.196930025 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196937677 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:14.196950400 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe minimum capture size for pixelformat H265
0:00:14.196956335 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:00:14.196982155 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.196991012 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:00:14.197011039 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe maximum capture size for pixelformat H265
0:00:14.197018149 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:00:14.197064059 766 0x7f8de800bf00 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7f8dcc012af0 Failed to determine interlace mode
0:00:14.197063864 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.197097698 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe minimum capture size for pixelformat VP90
0:00:14.197129574 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.197158560 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe maximum capture size for pixelformat VP90
0:00:14.197196031 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.197221388 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe minimum capture size for pixelformat VP80
0:00:14.197244864 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.197271883 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe maximum capture size for pixelformat VP80
0:00:14.197309445 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.197342580 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe minimum capture size for pixelformat H264
0:00:14.197366087 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:sink> Unable to try format: Unknown error -1
0:00:14.197384513 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:sink> Could not probe maximum capture size for pixelformat H264
0:00:14.197534327 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:src> Unable to try format: Unknown error -1
0:00:14.197577731 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:src> Could not probe minimum capture size for pixelformat NM12
0:00:14.197615349 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<nvv4l2decoder1:src> Unable to try format: Unknown error -1
0:00:14.197643258 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder1:src> Could not probe maximum capture size for pixelformat NM12
0:00:14.197669089 766 0x7f8de800b460 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7f8dc400d5c0 Failed to determine interlace mode
0:00:14.387476564 766 0x7f8de800b460 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder1> Duration invalid, not setting latency
0:00:14.387554040 766 0x7f8de800b460 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder1:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:14.388548257 766 0x7f8de800bf00 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:14.388617406 766 0x7f8de800bf00 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:14.390890033 766 0x7f8dc43136a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder1:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:14.391063405 766 0x7f8d9c017180 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
Frame Number= 1 Number of Objects= 1 Vahicle_count= 0 Person_count= 1
Frame Number= 2 Number of Objects= 1 Vahicle_count= 1 Person_count= 0
Frame Number= 3 Number of Objects= 2 Vahicle_count= 2 Person_count= 0
Frame Number= 4 Number of Objects= 3 Vahicle_count= 3 Person_count= 0
Frame Number= 5 Number of Objects= 3 Vahicle_count= 3 Person_count= 0
Frame Number= 6 Number of Objects= 2 Vahicle_count= 2 Person_count= 0
Frame Number= 7 Number of Objects= 3 Vahicle_count= 2 Person_count= 1
Frame Number= 8 Number of Objects= 3 Vahicle_count= 3 Person_count= 0
Frame Number= 9 Number of Objects= 5 Vahicle_count= 3 Person_count= 1
Frame Number= 10 Number of Objects= 3 Vahicle_count= 2 Person_count= 0
Frame Number= 11 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 12 Number of Objects= 6 Vahicle_count= 4 Person_count= 0
Frame Number= 13 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 14 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 15 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 16 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 17 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 18 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 19 Number of Objects= 3 Vahicle_count= 2 Person_count= 0
Frame Number= 20 Number of Objects= 5 Vahicle_count= 3 Person_count= 0
Frame Number= 21 Number of Objects= 6 Vahicle_count= 4 Person_count= 1
Frame Number= 22 Number of Objects= 5 Vahicle_count= 3 Person_count= 1
Frame Number= 23 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 24 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 25 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 26 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 27 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 28 Number of Objects= 5 Vahicle_count= 3 Person_count= 1
Frame Number= 29 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 30 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 31 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 32 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 33 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 34 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 35 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 36 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 37 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 38 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 39 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 40 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 41 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 42 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 43 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 44 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 45 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 46 Number of Objects= 5 Vahicle_count= 4 Person_count= 0
Frame Number= 47 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 48 Number of Objects= 4 Vahicle_count= 3 Person_count= 0
Frame Number= 49 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 50 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 51 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 52 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 53 Number of Objects= 3 Vahicle_count= 2 Person_count= 1
Frame Number= 54 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 55 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 56 Number of Objects= 5 Vahicle_count= 4 Person_count= 1
Frame Number= 57 Number of Objects= 5 Vahicle_count= 3 Person_count= 2
Frame Number= 58 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 59 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 60 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 61 Number of Objects= 5 Vahicle_count= 4 Person_count= 1
Frame Number= 62 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 63 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
Frame Number= 64 Number of Objects= 5 Vahicle_count= 3 Person_count= 2
Frame Number= 65 Number of Objects= 4 Vahicle_count= 3 Person_count= 1
0:00:15.413927419 766 0x2b3c760 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<filesink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
Looks like I have to implement group id in upstream elements. Can you give me a hint what it is? how it can be done?
