Pipetuner Dataset Setup
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 7.1
• TensorRT Version
I have few images and their corresponding annotations in txt files in [class x_center y_center width height] this format that I used for finetuning a yolov8 model, then exported to onnx and created the engine. But in all the documentation of Pipetuner it is asked to use Videos with annotation files. I don’t have original videos from where the frames were extracted, nor do I know how to create the annotation files for videos. Please help with this. How do I use my existing dataset to generate optimal parameters for my pipeline?
Images dataset is not supported by Pipetuner. The separated images can’t be used for tracker tunning.
Q1: Is it possible to only tune the detector parameters?
Q2: How to create our custom video dataset?
Can you please answer my queries?
Q1: Yes, it is possible. In the config file where you set the param ranges, you can comment out all tracker-related params, while leaving PGIE params. Then, PipeTuner will tune only PGIE params.
Q2: PipeTuner supports only video-based dataset. If you have images extracted from some videos, you can create videos by encoding those image frames into video using some video editing/creation tools, I believe.
