What is the per-second pixel processing capability of the ISP in the Jetson Xavier NX 16GB and 8GB modules. The specification only mentions support for 24-megapixel resolution but does not describe the per-second processing capability. We need to evaluate its ISP processing capacity for connecting multiple RAW cameras.
hello Luke.Li,
you may dig into ISP clocks of Xavier NX, which is 576Mhz, you should also considering with 2-Pixels/clock, and translates it with 15% off.
hence, ISP throughput of Xavier NX will be… 576Mhz * 2 * 0.85 = 979.2 MPixels/Sec.
Thanks Jerry. This is what I want.
