I’ve just bought a quadro k4200, installed it in a Dell t7810, installed ubuntu 20.04 linux, and connected to a samsung c32jg50 monitor by display port cable. Ubuntu installed the nvidia 440.64 driver and it has set the max resolution at 1920 x 1080. The screen is supposed to do up to 2560x1440. Is there a way to change my card to support this?
Thx, J
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post. You will have to rename the file ending to something else since the forum software doesn’t accept .gz files (nifty!).
nvidia-bug-report.log (362.0 KB)
This is a gz file, if you rename it and add .gz to the end.
Thanks a bunch, J
Looks like the monitor is switched to DP1.1, please use the monitor’s OSD menu to switch it to DP1.2.
It may have been, not sure, but it is set to 1.2 now. What should I do next? Thx.
The problem is that the monitor sends an edid that tells it only supports 1920x1080@60 so I suspected it was set to DP1.1. Please post the output of
xrandr --props
with monitor set to DP1.2.
Do you use some kind of converter or plain DP cable? Did you already check replacing the cable?
output from xrandr in this file
Thx. J
(Attachment stuff.txt is missing)
sending file didn’t work, here it is in all its glory
jamaas:~$ xrandr --props
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: VGA
supported: VGA
ConnectorType: DVI-I
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
DVI-I-1 disconnected (normal left inverted right x axis y axis)
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 0
non-desktop: 0
supported: 0, 1
DP-0 disconnected (normal left inverted right x axis y axis)
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: DisplayPort
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
DP-1 disconnected (normal left inverted right x axis y axis)
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 3
_ConnectorLocation: 3
non-desktop: 0
supported: 0, 1
DP-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 700mm x 390mm
_MUTTER_PRESENTATION_OUTPUT: 0
EDID:
00ffffffffffff004c2d840f41305843
071e0104a54627783a6d71a4584e9f27
0f5054bfef8081c0810081809500a9c0
b300714f0101023a801871382d40582c
4500ba892100001e000000fd00324b1e
5111000a202020202020000000fc0043
33324a4735780a2020202020000000ff
0048345a4e3230303031350a202001e0
020313f146901f041303122309070783
01000000000000000000000000000000
00000000000000000000000000000000
00000000000000000000000000000018
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorNumber: 2
non-desktop: 0
supported: 0, 1
1920x1080 60.00 + 59.94 50.00*
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorNumber: 3
non-desktop: 0
supported: 0, 1
The monitor still tells it only supports 1080p. If you’re not using any converters and the cable is fully functional, you should contact Samsung support about it.
Thanks, for that, will give it a try. I’m not using any converters, and it is the cable that came in the box, so you would expect it to work.
Best,
J
Thanks generix, it turns out the monitor I was sold … is not what I’ve been delivered! So this is in fact the max resolution this one will handle! So you and all the messages were correct, thanks for help and sorting this one out.
Best, J
Hi I have a T7810 and would like to install Ubuntu 14.0 lts can you tell me how I can do this for this machine.
Thakz
