Hi! I’m finding that for the T4 and M60, the 435.21 driver works on resolutions greater than 2560x1600, but the driver versions after this point don’t work.
This is what I’m running:
nvidia-settings --assign CurrentMetaMode="nvidia-auto-select +0+0 {ViewPortIn=5120x3200}"
On the 435 driver, xrandr | head gives me this output:
Screen 0: minimum 8 x 8, current 5120 x 3200, maximum 2560 x 1600
DVI-D-0 connected primary 5120x3200+0+0 (normal left inverted right x axis y axis) 530mm x 300mm
1280x960 60.00*+ 85.00
But on more recent drivers, the resolution will never go above 2560x1600. In particular, it won’t go over 4096000 pixels. So a 2048x2048 resolution will work fine, but a 2049x2048 resolution will not.
I’m running a Virtual X screen in both of these cases.
Does anyone know why future drivers seem to have a limit? Thank you!
