I’m connecting to a virtual workstation using Nice DCV, and I’m unable to use resolutions higher than 2560x1600. What causes this limitation? Here’s the error in Xorg log file.
[ 11558.675] (--) NVIDIA(GPU-0): NVIDIA VGX (DFP-0): connected
[ 11558.675] (--) NVIDIA(GPU-0): NVIDIA VGX (DFP-0): External TMDS
[ 11558.675] (WW) NVIDIA(GPU-0): Mode (3840 x 2400) larger than per-head max resolution
[ 11558.675] (WW) NVIDIA(GPU-0): supported (2560 x 1600)
I read that some vGPU licenses are limited to 2560x1600. But according to nvidia-smi this is not a vGPU.
# nvidia-smi vgpu
No supported devices in vGPU mode
# nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Thu Jun 15 02:38:57 2023
Driver Version : 525.89.02
CUDA Version : 12.0
Attached GPUs : 1
GPU 00000000:00:1E.0
Product Name : Tesla T4
Product Brand : NVIDIA
Product Architecture : Turing
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : Disabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 1325121103675
GPU UUID : GPU-f292bdfc-c478-a47e-4196-af022ca72721
Minor Number : 0
VBIOS Version : 90.04.96.00.02
MultiGPU Board : No
Board ID : 0x1e
Board Part Number : 900-2G183-A800-001
GPU Part Number : 1EB8-895-A1
Module ID : 1
Inforom Version
Image Version : G183.0200.00.02
OEM Object : 1.1
ECC Object : 5.0
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : 525.89.02
GPU Virtualization Mode
Virtualization Mode : Pass-Through
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x00
Device : 0x1E
Domain : 0x0000
Device Id : 0x1EB810DE
Bus Id : 00000000:00:1E.0
Sub System Id : 0x12A210DE
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Device Current : 3
Device Max : 3
Host Max : N/A
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Atomic Caps Inbound : N/A
Atomic Caps Outbound : N/A
Fan Speed : N/A
Performance State : P0
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 15360 MiB
Reserved : 399 MiB
Used : 782 MiB
Free : 14178 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 11 MiB
Free : 245 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
SRAM Correctable : 0
SRAM Uncorrectable : 0
DRAM Correctable : 0
DRAM Uncorrectable : 0
Aggregate
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending Page Blacklist : No
Remapped Rows : N/A
Temperature
GPU Current Temp : 39 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 96 C
GPU Slowdown Temp : 93 C
GPU Max Operating Temp : 85 C
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 24.98 W
Power Limit : 70.00 W
Default Power Limit : 70.00 W
Enforced Power Limit : 70.00 W
Min Power Limit : 60.00 W
Max Power Limit : 70.00 W
Clocks
Graphics : 585 MHz
SM : 585 MHz
Memory : 5000 MHz
Video : 810 MHz
Applications Clocks
Graphics : 585 MHz
Memory : 5001 MHz
Default Applications Clocks
Graphics : 585 MHz
Memory : 5001 MHz
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 1590 MHz
SM : 1590 MHz
Memory : 5001 MHz
Video : 1470 MHz
Max Customer Boost Clocks
Graphics : 1590 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Fabric
State : N/A
Status : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 92301
Type : G
Used GPU Memory : 92 MiB
Process ID : 92387
Type : G
Used GPU Memory : 68 MiB
Process ID : 93962
Type : C+G
Used GPU Memory : 535 MiB
OS: Rocky Linux 8.7
Platform: AWS EC2 g4dn.8xlarge
GPU: Tesla T4
Driver: 525.89.02
Xorg.0.log (24.3 KB)
