Hi there, I’m using HP Zbook laptop with GeForce M1000M graphics card. I have connected over HDMI port external display Dell U3011 with native resolution 2560x1600. Max resolution I can get from Ubuntu 16.04 is 1600x1200.
From Windows 10, however, using the same setup (Dell U3011 over the same HDMI port), I get full 2560x1600 resolution with no problem.
$ sudo lshw -numeric -C display
*-display
description: VGA compatible controller
product: GM107GLM [Quadro M1000M] [10DE:13B1]
vendor: NVIDIA Corporation [10DE]
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:132 memory:e3000000-e3ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:3000(size=128) memory:e4080000-e40fffff
PS. I use HDMI to DVI cable, so HDMI end goes to laptop, DVI end goes to external display.
nvidia-bug-report.log.gz (181 KB)
