I updated my Archlinux system from 450.66 to 455.23.04. Monitor is a Samsung TV Q7FN 55" from 2018.
With 450.66 xrandr returns:
$ xrandr -q
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 1210mm x 680mm
3840x2160 30.00 + 59.94 50.00 29.97 25.00 23.98 23.98
4096x2160 59.94 50.00 29.97 25.00 24.00 23.98
1920x1080 119.88* 100.00 60.00 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1366x768 59.79
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
With 455.23.04:
$ xrandr -q
DP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
1920x1080 60.00*+ 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1366x768 59.79
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
Same resolution loss happens in ubuntu 20.04. It ends up in 640x320.
However to get back (in case you need to do some work you can do
Today Sept 28th, 2020 I did an update via the ubunu update tool. Once done the graphics no longer works properly the resolution I get is 640x320.
The solution that works is to go to the NVIDIA Web page and download the 450 driver. Than you need to install that driver with sudo sh FILNAME_OF_THE_RUN_FILE.run
After the next reboot, your screen will be good again. I checked on also the 32 bit option and recreated the X settings.
It would be nice to work with ubuntu to make sure this does not happen.
wget https://us.download.nvidia.com/XFree86/Linux-x86_64/450.66/NVIDIA-Linux-x86_64-450.66.run
sudo sh NVIDIA-Linux-x86_64-450.66.run
sudo restart -h now
Well indeed reverting to 450.66 fixes the issue, but that is not a solution as far as 455.23.04 is concerned. That said, it is unadvised to use the run file on a distribution like Ubuntu or Archlinux. Prefer downgrading the packages instead.
I had a look at my bug report files and found out something from the Xorg.0.log files:
For 450.66:
[ 5.036] (–) NVIDIA(GPU-0): SAMSUNG (DFP-1): connected
[ 5.036] (–) NVIDIA(GPU-0): SAMSUNG (DFP-1): Internal TMDS
[ 5.036] (–) NVIDIA(GPU-0): SAMSUNG (DFP-1): 600.0 MHz maximum pixel clock
[ 5.101] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 5.101] (==) NVIDIA(0): will be used as the requested mode.
[ 5.102] (==) NVIDIA(0):
[ 5.103] (II) NVIDIA(0): Validated MetaModes:
[ 5.103] (II) NVIDIA(0): “DFP-1:nvidia-auto-select”
[ 5.103] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
For 455.23.04:
[ 5.308] (–) NVIDIA(GPU-0): SAMSUNG (DFP-1): connected
[ 5.308] (–) NVIDIA(GPU-0): SAMSUNG (DFP-1): Internal TMDS
[ 5.308] (–) NVIDIA(GPU-0): SAMSUNG (DFP-1): 165.0 MHz maximum pixel clock
[ 5.358] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 5.358] (==) NVIDIA(0): will be used as the requested mode.
[ 5.360] (II) NVIDIA(0): Validated MetaModes:
[ 5.360] (II) NVIDIA(0): “DFP-1:nvidia-auto-select”
[ 5.360] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
There is a discrepancy between the maximum pixel clock values (165 vs 600 MHz), and am wondering if this in the end affects the virtual screen size as determined by nvidia-auto-select.
Also, xrandr --verbose (line 8285 and 8378 of the bug reports for 455 and 450, repectively) shows that both versions read the same EDID information, however the computed modes are different, maxing out at 1920 for 455, and with different maximum clock frequencies.
