Power/login loop after hibernation using NVIDIA driver (also causes VS Code container failures)
nvidia-bug-report.log (2.1 MB)
I have a NVIDIA 2060 and I am running Ubuntu 22.04, I am using the NVIDIA 535.154.05 driver and I have issues after hibernation on my laptop that doesn’t occur when I select my Intel MESA driver, only when I use “on-demand” or “performance” mode.
On startup my laptop is fine, however, when I shut the lid and open it again, after logging in, it either powers off the laptop and then logs me back in once I press the power button back on, or it just logs me out and gives me black screens. After turning the power back on and/or logging back in, these problems repeat. As it’s failing, it gives a lot of ACPI errors on the screen such as “aborting method”, “AE_NOT_EXIST” and some others.
Additionally, I also noticed that using the NVIDIA driver also causes my local VS Code containers to fail with error code “/snap/code/152”, this doesn’t happen when using my Intel driver.
After trying to run the “sudo startx – -logverbose 6” command, I get this, but running “sudo nvidia-bug-report.sh” worked well (results above).
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
Current Operating System: Linux lewis-Blade-15-Mid-2019-Base 6.5.0-18-generic #18~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Wed Feb 7 11:40:03 UTC 2 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5.0-18-generic root=UUID=1a9e7ae4-cd5b-456c-a2d3-6fe569335236 ro quiet=1
xorg-server 2:21.1.4-2ubuntu1.7~22.04.8 (For technical support please see Enterprise open source support | Ubuntu)
Current version of pixman: 0.40.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Sat Feb 24 11:50:52 2024
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Without giving too much away, here is my attempt at opening the container on a local project I have.
[1960 ms] Start: Run: docker inspect --type container 012a2240fc40
[1984 ms] Start: Starting container
[1984 ms] Start: Run: docker start 012a2240fc40fb4f303d5efb838f06315a19336b578ca6bc6c5e6f30bedf0a15
[2003 ms] Error response from daemon: invalid mount config for type “bind”: bind source path does not exist: /run/user/1000/wayland-0
Error: failed to start containers: 012a2240fc40fb4f303d5efb838f06315a19336b578ca6bc6c5e6f30bedf0a15
[2005 ms] Exit code 1
[2005 ms] Error: Command failed: docker start 012a2240fc40fb4f303d5efb838f06315a19336b578ca6bc6c5e6f30bedf0a15
[2006 ms] at J$ (/home/user/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js:464:1253)
[2006 ms] at $J (/home/user/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js:464:997)
[2006 ms] at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
[2006 ms] at async tAA (/home/user/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js:481:3660)
[2006 ms] at async CC (/home/user/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js:481:4775)
[2007 ms] at async NeA (/home/user/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js:614:11107)
[2007 ms] at async MeA (/home/user/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js:614:10848)
[2013 ms] Exit code 1
[2018 ms] Command failed: /snap/code/152/usr/share/code/code /home/user/.vscode/extensions/ms-vscode-remote.remote-containers-0.338.1/dist/spec-node/devContainersSpecCLI.js up --user-data-folder /home/user/.config/Code/User/globalStorage/ms-vscode-remote.remote-containers/data --container-session-data-folder /tmp/devcontainers-7a805015-1a53-4940-8e0a-81ed27d34d3d1708736703982 --workspace-folder /home/user/projects/foo --workspace-mount-consistency cached --id-label devcontainer.local_folder=/home/user/projects/foo --id-label devcontainer.config_file=/home/user/projects/foo/.devcontainer/devcontainer.json --log-level debug --log-format json --config /home/user/projects/foo/.devcontainer/devcontainer.json --default-user-env-probe loginInteractiveShell --mount type=volume,source=vscode,target=/vscode,external=true --skip-post-create --update-remote-user-uid-default on --mount-workspace-git-root
[2018 ms] Exit code 1
