I’m using driver version 319.23. I’ve also tried 319.17. Preferred power mode is set to Adaptive in NVIDIA’s X Server Settings, but it only shows Performance Level 2 (maxed).
Is this a known regression? I think it worked correctly, with Performance Level dropping to 0 when running regular desktop and only going higher with OpenCL or similar loads, back in the 313.30 release and earlier.
When X was started with only 2x DVI output, power level were low. When HDMI was plugging in, it becomes available but output remained low.
Aside: xrandr reported HDMI-0 output available, but it would indicate “no such output exists” for a while. Eventually it would start throwing errors. I was only able to active HDMI-0 output via nvidia-settings utility.
When HDMI output was then activated, power level became maxed out. When HDMI is activated (plugged in) at start, they are also maxed.
Disabling the display via xrandr --output HDMI-0 --off turned off the display but power levels remain maxed.
I will be sending nvidia-bug-report logs to the linux-bugs@n.c address.
I just installed Linux Mint 15. My Powermizer worked for a couple of reboots (installing “important” stuff) and now it is stuck aswell on max. performance. I think it started when I switched to the WebGL login theme - switching back, reinstalling the driver or using a newer version (310 versus 313). No matter what I do the adaptive feature doesn’t work anymore.
I use a Lenovo W510 with a FX880 Quadro. I attached the bug report but since nothing is crashing I doubt there is much usefull information. So far I just let Mint run without any open applications and the GPU still doesn’t scale back. nvidia-bug-report.log.gz (61.5 KB)
You only seem to have one device connected? Maybe it is not the same problem.
I just run fluxbox for WM, so there is nothing that is causing any load when DVI + HDMI are connected at same time. With just HDMI or DVI, no problem with power consumption. 3 displays, power spike.
As per screenshot, the lowest frequency it gets to on Performance Level 2 is 850MHz. And it never goes down to lower Performance Level. Still burning energy for nothing…
Thank you. That allows for changing PowerMizer levels manually, but they were all fixed (ie. not changing). PerfLevelSrc did not affect whether they change depending on load or not. Your setting just make my card stuck at Performance Level 0.
Is it really this difficult to make Performance Levels adaptive? It worked fine in the past. I can’t really downgrade because those driver versions results in lots of Xid errors.
Looks like I didn’t test my configuration thoroughly enough. I thought adaptive mode was working properly on my machine after I tried playing some HD video files with mplayer/VDPAU and saw the performance mode change to level 1, but now I’ve tried playing a few games and it just stayed in level 0. Changing the mode in nvidia-settings to maximum performance doesn’t do anything either.
I’m convinced that the PowerMizer display is bugged, and the card actually does what it’s supposed to do. I don’t have the time to test, but I can show you how to test.
Compile and run the patch below, and use nvidia-smi to look at P-state and clock information that the patch will enable, and you can confirm if it’s PowerMizer being bugged or not:
[url]https://github.com/CFSworks/nvml_fix[/url]
I have the same problem as Franster. My GPU is a NVS 5200M in a Dell Inspiron 6540 notebook. Driver version is 325.15. I didn’t try older versions.
PowerMizer doesn’t switch to lower levels when there’s no activity and more than one monitor is attached. In particular:
1 LCD panel - power levels work correctly
1 DVI output - power levels work correctly
1 LCD panel + 1 DVI outpu - power levels maxed
When the power levels work correctly, I see the levels switching down correctly on the PowerMizer tab in nvidia-settings. Also, temperature drops down to 40°C. When two displays are attached, the power levels don’t go down and temperature always remains somewhere above 55°C, making one of the fans run permanently.
Same problem here with a GTX 560m on an ASUS G74SX with 325.15. driver. I’ve tested this on Gentoo current with tuxonice-sources-3.9.4 kernel and pf-sources-3.10.1 kernel
Laptop LCD panel - power levels work correctly
Laptop LCD panel + VGA output - power levels maxed
Laptop LCD panel + DVI output - power levels maxed
Adding the PowerMizerParameters didn’t worked for me
It worked perfectly and correctly with older drivers. I have all displays set at 60Hz, yet HDMI is listed as 60.00 while the other two (DVI) are 60.02.
Again, this worked quite correctly with older drivers (around Nov. 2012). And I would still use older drivers if they didn’t suffer from the dreaded Xid errors and would actually compile with modern kernels… (aside from some terrible “lag” that remains with Wine with Kepler where my very old 9400GT experience was much smoother).
adamm@mira:~$ xrandr --screen 0
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
VGA-0 disconnected primary (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 708mm x 398mm
1920x1080 60.0*+ 60.0 59.9 30.0 24.0 60.1 60.0
1600x1200 60.0
1360x768 60.0
1280x1024 75.0 60.0
1280x720 60.0 59.9
1024x768 75.0 70.1 60.0
800x600 75.0 72.2 60.3 56.2
720x480 59.9
640x480 75.0 72.8 60.0 59.9
adamm@mira:~$ xrandr --screen 1
Screen 1: minimum 8 x 8, current 2048 x 1280, maximum 16384 x 16384
DVI-D-0 connected primary 1024x1280+0+0 left (normal left inverted right x axis y axis) 376mm x 301mm
1280x1024 60.0*+ 75.0
1152x864 75.0
640x480 75.0 72.8 59.9
DVI-D-1 connected 1024x1280+1024+0 left (normal left inverted right x axis y axis) 376mm x 301mm
1152x864 75.0
Actually, it’s not just the refresh rates that have to match – the entire mode timings have to match exactly. That’s resolution (active region) as well as blanking timings and polarities. We only lock the displays together if everything matches.
