Hi I am trying to install caffe on my TX2,when I make the Makefile.config,I found this message on my terminal:
CXX src/caffe/util/db_leveldb.cpp
CXX src/caffe/internal_thread.cpp
CXX src/caffe/solver.cpp
AR -o .build_release/lib/libcaffe.a
LD -o .build_release/lib/libcaffe.so.1.0.0
/usr/bin/ld: skipping incompatible /usr/local/cuda/lib64/libcudnn.so when searching for -lcudnn
CXX/LD -o .build_release/tools/upgrade_net_proto_text.bin
CXX/LD -o .build_release/tools/compute_image_mean.bin
CXX/LD -o .build_release/tools/extract_features.bin
CXX/LD -o .build_release/tools/caffe.bin
CXX/LD -o .build_release/tools/upgrade_solver_proto_text.bin
CXX/LD -o .build_release/tools/convert_imageset.bin
CXX/LD -o .build_release/tools/upgrade_net_proto_binary.bin
CXX/LD -o .build_release/examples/cifar10/convert_cifar_data.bin
CXX/LD -o .build_release/examples/siamese/convert_mnist_siamese_data.bin
CXX/LD -o .build_release/examples/cpp_classification/classification.bin
CXX/LD -o .build_release/examples/mnist/convert_mnist_data.bin
my setting is ubuntu16.04 cuda 8.0 cudnn6.0.21
I an sure I have install the cudnn6.0.21 and also run an example about it.
Could anyone give some suggestions? Any help is appreciated.
Thanks a lot!
