Hello.
I am a fresh owner of jetson nano 2gb.
Currently I control the nano via a raspberry pi 4 (via VNC).this also works quite smoothly. Now I want to use the jetson nano headless(without UI). Therefore I have the command “sudo systemctl set-default multi-user.target” the UI off. When I connect the monitor to the jetson nano I can see that it works. But when I try to connect the raspberry pi via VNC to the jetson nano I get the following error message “the connection has been rejected by the computer” (my German to English translation).
Can anyone help me?
Thank you very much.
