Hi there.
I’m having troubles accessing my jetson NANO from a remote pc via VNC. Something you can do with 3 clicks on a €20 raspberry, but seems impossible to do on a €120 board. lol.
I can’t attach my NANO to any HDMI display. I need to be able to have full control with mouse and keyboard from a remote (windows) pc, connected to the same router.
What I already tried:
I started from this guide: https://developer.nvidia.com/embedded/learn/tutorials/vnc-setup . (did all via ssh terminal from another pc)
It works on installing and setting up things(i guess), but then no clues on how to go on. Just rebooting and starting the VNC viewer from remote pc doesn’t work.
Then I looked here: Jetson Nano vnc/headless connections - #3 by infojk16g .I tried to do
export DISPLAY=:0 # Enable the VNC server gsettings set org.gnome.Vino enabled true gsettings set org.gnome.Vino prompt-enabled false gsettings set org.gnome.Vino require-encryption false # Reboot the system so that the settings take effect sudo reboot
As suggested in the post
then tried to create an openvino executable file as suggested by another user:
#!/bin/bash
export DISPLAY=:0
/usr/lib/vino/vino-server &
but the output is:
Unable to init server: Could not connect: Connection refused
Cannot open display: :0
Run ‘vino-server --help’ to see a full list of available command line options
also running directly vino-server with different DISPLAY settings gives me the same result.
…And from there i’m really stuck. And I find a little frustrating that the documentation doesn’t provide an specific suggestion.
additional information: trying running an X server using putty and XLaunch works, but i’m able to open only one gui-application at a time (eg. nautilus, firefox etc…) but the display gets disconnected every 2 minutes, and I am still unable to access the whole linux GUI…
Any suggestions?
