Vnc won't work without jetson connected to monitor
Jetson nano 4gb Developer kit
jetpack 4.5.1
Followed instructions in this link
additionally also had to add: /usr/lib/vino/vino-server in startup applications
In my laptop i installed vncviewer and gave ip address of my jetson connected to same network.
I can only see Nvidia logo
But when i connect jetson with my monitor thorugh hdmi, i can also see the desktop of jetson on my vnc viewer in my laptop
but i want to see it without connecting monitor to jetson. Can someone help me?
The L4T-README volume will mount on the other computer, including files such as README-vnc.txt.
This readme file has below content.
Setting the Desktop Resolution
The desktop resolution is typically determined by the capabilities of the
display that is attached to Jetson. If no display is attached, a default
resolution of 640x480 is selected. To use a different resolution, edit
/etc/X11/xorg.conf and append the following lines:
Section "Screen"
   Identifier    "Default Screen"
   Monitor       "Configured Monitor"
   Device        "Tegra0"
   SubSection "Display"
       Depth    24
       Virtual 1280 800 # Modify the resolution by editing these values
   EndSubSection
EndSection
i tried this,
and unfortunately, the situation is the same.
i connect jetson through vnc, i see only nvidia logo
but when i connect the jetson with monitor through hdmi i can see desktop both in monitor and on vnc
thats how my xorg.conf file looks like…
autostart
gdm3 conf
also i did reboot after making above changes
What is the result when you use xrandr command ?
can’t open display
After using “export DISPLAY=:0” ?
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
HDMI-0 disconnected primary (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
i was hoping it will work, so i did a reboot now.
and xrandr now gives “can’t open display”
and still vnc shows only nvidia logo when jetson is connected without monitor
May need to try something like this:
this makes it worse,
now i can’t see anything either on monitor or on vnc
Then maybe you can try other vnc server suggested by other users. There are lots of posts on the forum.
Sharing that this worked for me.
I did not connect a monitor to Jetson Nano yet I can still connect via VNC.
The gdm3 conf is at /etc/gdm3/custom.conf just in case
