Problem CSI camera Jetson Nano OpenCV
I am new with the Jetson Nano board and I have some troubles with my CSI camera through python
The goal to this program is to classify the frames from the CSI camera of my Jetson Nano with a deep learning model.
I trained it with pictures I took with the CSI camera with the command : nvgstcapture-1.0 --image-res=3 in the console.
The program is working well when I use a USB webcam with the command : cap = cv2.VideoCapture(1)
I can get my visualize_model function for each frames so everything is fine.
But I d like to use the CSI camera because I trained my model with.
When I try to use the CSI camera with GSTREAMER, the window with the frame opens (there is a big latency, like 2 or 3 sec) and either the window crashes or either I can press Escape key to close the windows but the program is not closing (I have to stop it with keyboard interrupt) and it doesn t print my visualize_model function…
Is someone knows how I can fix my problem ?
Here the program :
> import cv2
> import torch
> import torch.nn as nn
> import torch.optim as optim
> from torch.optim import lr_scheduler
> import numpy as np
> import torchvision
> from torchvision import datasets, models, transforms
> import os
> import time
> import copy
> import torch.nn.functional as f
> from PIL import Image
> def gstreamer_pipeline(
>     capture_width=1280,
>     capture_height=720,
>     display_width=1280,
>     display_height=720,
>     framerate=60,
>     flip_method=0,
>     return (
>         "nvarguscamerasrc ! "
>         "video/x-raw(memory:NVMM), "
>         "width=(int)%d, height=(int)%d, "
>         "format=(string)NV12, framerate=(fraction)%d/1 ! "
>         "nvvidconv flip-method=%d ! "
>         "video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
>         "videoconvert ! "
>         "video/x-raw, format=(string)BGR ! appsink"
>             capture_width,
>             capture_height,
>             framerate,
>             flip_method,
>             display_width,
>             display_height,
> data_dir = '/home/Name/Classification'
> model_dir = data_dir+"/best_model_mobilenet_v2.pth"
> device = torch.device("cuda:0" if torch.cuda.is_available() else "cpu")
> model = torch.load(model_dir)
> model = model.to(device)
> was_training = model.training
> model.eval()
> def visualize_model(model, image=''):
>     imsizel=700
>     imsizeL=round((imsizel/16)*9)
>     data_transforms =transforms.Compose([transforms.Resize((imsizeL,imsizel)),transforms.ToTensor(),transforms.Normalize([0.485, 0.456, 0.406], [0.229, 0.224, 0.225])])
>     img = Image.open(image)
>     image_datasets = data_transforms(img)
>     dataloaders = torch.utils.data.DataLoader(image_datasets, batch_size=1, shuffle=False, num_workers=0)
>     class_names = ["B", "G"]
>     with torch.no_grad():
>         inputs = image_datasets
>         inputs = inputs.to(device)
>         outputs = model(inputs[None])
>         _, preds = torch.max(outputs, 1)
>         precision = f.softmax(outputs, dim=1)
>         print('-'*20)
>         for k in range(0, len(class_names)):
>             print("Probability ", class_names[k] + " : ", round(precision[0][k].item(), 3))
>         print('-'*20 + '\n')
>         return
> #cap = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER)
> if cap.isOpened():
>     window_handle = cv2.namedWindow("CSI Camera", cv2.WINDOW_AUTOSIZE)
>     while cv2.getWindowProperty("CSI Camera", 0) >= 0:
>         ret_val, img = cap.read()
>         cv2.imwrite('/home/Name/Classification/CamCap/cap.jpg', img)
>         image = '/home/Name/Classification/CamCap/cap.jpg'
>         visualize_model(model=model, image = image)
>         cv2.imshow("CSI Camera", img)
>         keyCode = cv2.waitKey(30) & 0xFF
>         if keyCode == 27:
>             break
>     cap.release()
>     cv2.destroyAllWindows()
```Preformatted text
Hello !
I finally managed to make my CSI camera works
I used the nanocamera module instead of using Gstreamer
To install it : pip3 install nanocamera
GitHub page : GitHub - thehapyone/NanoCamera: A simple to use camera interface for the Jetson Nano for working with USB and CSI cameras in Python.
Thank you very much
Glad to know your camera works, thanks for sharing.
