Hello Everyone
I have been trying to parse a network which has slice layer in tensorrt for image classification. There is no support for slice layer in tensorrt and I am using the follow git repo as reference
https://github.com/Goingqs/TensorRT-Prelu for implementing slice layer as a plugin.
I have tried to integrate the code with the code given in the following git repo https://github.com/dusty-nv/jetson-inference. The following code snippet was inserted in tensorNet.cpp
nvinfer1::IPlugin* PluginFactory::createPlugin(const char* layerName, const nvinfer1::Weights* weights, int nbWeights){ //int nbWeights){
assert(isPlugin(layerName));
//printf("we are in wrong call\n");
std::string strName {layerName};
std::transform(strName.begin(),strName.end(),strName.begin(),::tolower);
if (strName.find("slice") != std::string::npos){
_nvPlugins[layerName] = (IPlugin*)(new SliceLayer<2>({x,y}));//x and y are numbers
based on the slice parameters
return _nvPlugins.at(layerName);
The slice layer in implemented in following code snippet in tensorNet.cpp
PluginFactory pluginFactory;
parser->setPluginFactory(&pluginFactory); //Plugin Factory
const nvcaffeparser1::IBlobNameToTensor *blobNameToTensor =
parser->parse(deployFile.c_str(), // caffe deploy file
modelFile.c_str(), // caffe model file
*network, // network definition that the parser will populate
modelDataType);
When I try to run the code I am able to parse and serialize the engine. However I get a Segmentation fault when I try to deserialize the engine. The problematic section of code where the error occurs is shown below with some custom output
printf("trying to seek stream from gieModel\n");
gieModelStream.seekg(0, std::ios::end);
const int modelSize = gieModelStream.tellg();
std::cout<< "model size is "<< modelSize <<std::endl;
gieModelStream.seekg(0, std::ios::beg);
printf("gieModel is read \n");
void* modelMem = malloc(modelSize);
std::cout<<"modelMem is built"<<std::endl;
if( !modelMem )
printf(LOG_GIE "failed to allocate %i bytes to deserialize model\n", modelSize);
return 0;
std::cout<<"going to read the gieModelStream to modelMem"<<std::endl;
gieModelStream.read((char*)modelMem, modelSize);
std::cout<< "Going to deserialize engine"<< std::endl;
nvinfer1::ICudaEngine* engine = infer->deserializeCudaEngine(modelMem, modelSize, NULL);
std::cout<<"Engine has been built"<<std::endl;
The output snippet printed is shown below
runtime logger created
model size is 11340184
gieModel is read
modelMem is built
The problem occurs when the engine is being deserialized. I am not sure why.
It would be really helpful if I can get any inputs and help on this issue.
