Problem playing h265 from blackmagic hyperdeck
I have two files, both recorded on the Blackmagic Hyperdeck
  1. http://35.176.202.205/files/HyperDeck_0010.mp4 - 2160p60 HEVC h265
  1. http://35.176.202.205/files/HyperDeck_0011.mp4 - 1080p60 h264
On the Nvidia Nano Dev kit 2Gb & 4Gb on Jetpack 4.4 & 4.5.1 I run:
gst-play-1.0 HyperDeck_0010.mp4
gst-play-1.0 HyperDeck_0011.mp4
and both commands work great video plays no problem
On the Xavier AGX dev kit, on Jetpack 4.4, 4.5.1 & 4.6.1 I run the same commands:
and the first file (2160p60 HEVC h265) fails to run. Here is the output
File 1 (FAIL)
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 279
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 279
Redistribute latency…
ERROR Internal data stream error. for file:///SSD/Media/HyperDeck_0010.mp4
ERROR debug information: qtdemux.c(6073): gst_qtdemux_loop (): /GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
streaming stopped, reason not-negotiated (-4)
Reached end of play list.
File 2 (Success)
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:03.0 / 0:00:03.0
Urgently need some assistance with this. Any ideas what could be going wrong?
The content is 10-bit h265 stream an decoded YUV is in YUV420 10-bit. You would need nvvidconv to convert to 8-bit for video playback. Please try
$ gst-play-1.0 --videosink="nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! nv3dsink" file:///home/nvidia/HyperDeck_0010.mp4
can also try
$ gst-launch-1.0 filesrc location= HyperDeck_0010.mp4 ! qtdemux ! h265parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nv3dsink
On Jetson Nano 10-bit content is decoded into 8-bit, so the conversion is not required.
Thank you for the explanation. Much appreciated.
