Problem running tensorflow
Hi, I run a code, then I get to the next section and it just runs the code for me on the CPU, how do you handle it?
Also I installed Index of /compute/redist/jp/v51 tensorflow==2.11.0+nv23.01
in a virtual environment with jupyter notebook
with tf.device(“/GPU:0”):
model = Sequential()
 # CONVOLUTIONARY LAYER
 model.add(Conv2D(filters=32, kernel_size=(4,4),input_shape=(28, 28, 1), activation='relu',))
 # POOLING LAYER
 model.add(MaxPool2D(pool_size=(2, 2)))
 # FLATTEN IMAGES FROM 28 by 28 to 764 BEFORE FINAL LAYER
 model.add(Flatten())
 # 128 NEURONS IN DENSE HIDDEN LAYER (YOU CAN CHANGE THIS NUMBER OF NEURONS)
 model.add(Dense(128, activation='relu'))
 # LAST LAYER IS THE CLASSIFIER, THUS 10 POSSIBLE CLASSES
 model.add(Dense(10, activation='softmax'))
 # https://keras.io/metrics/
 model.compile(loss='categorical_crossentropy',
               optimizer='adam',
               metrics=['accuracy']) # we can add in additional metrics https://keras.io/metrics/
2023-04-11 08:47:14.896328: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
Your kernel may have been built without NUMA support.
2023-04-11 08:47:15.052247: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:15.052754: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:15.057740: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:15.058241: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:15.058632: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:17.844735: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:17.845461: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:17.845639: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1703] Could not identify NUMA node of platform GPU id 0, defaulting to 0. Your kernel may not have been built with NUMA support.
2023-04-11 08:47:17.845954: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:984] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2023-04-11 08:47:17.846192: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1616] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 2393 MB memory: → device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2
Could you check the GPU functionality in the virtual environment first?
It looks like the CUDA can work on your environment.
If you are asking about the NUMA message, it is a harmless warning.
