Tensorflow not finding any GPUs
I am running a Jeston Xaiver NX on a freash install of Jectpack 5.01. I used the SDKmanger tool to flash jetpack and the developer tools to the NVMe ssd.
I followed the instructions to install tensorflow here Installing TensorFlow for Jetson Platform :: NVIDIA Deep Learning Frameworks Documentation
I am running movenet tflite model downloaded from here TensorFlow Hub
Tensorflow will only run on the CPU and I get this error for the GPUs
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
2022-06-21 19:47:57.196589: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
Your kernel may have been built without NUMA support.
2022-06-21 19:47:57.326235: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:57.326799: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:57.330058: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:57.330522: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:57.330910: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:58.964216: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:58.964669: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:58.964869: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1609] Could not identify NUMA node of platform GPU id 0, defaulting to 0. Your kernel may not have been built with NUMA support.
2022-06-21 19:47:58.965176: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:938] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-06-21 19:47:58.965446: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1525] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 7123 MB memory: → device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2
Usually, NUMA is a harmless warning.
Based on your log below, TensorFlow detects the GPU correctly.
Is there any issue when running the model in GPU mode?
It seems this model (tflite movenet) runs poorly on Jetson. I can get 70 FPS running on my laptop only using CPU but on Jetson it only gets 13 FPS and also a big delay between what is happening in front of camera and when the stream comes through. I have changed to trt_pose model although it is a much heavier model it runs much faster as it is optimized for Jetson. It runs faster than the camera and I get real time between what is happening in front of the camera and the output.
Have you maximized the device performance first?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
In the GUI I set the highest performance 20w 6 cores
Could you try the jetson_clocks script?
It will fix the frequency to the maximum.
The default mode is the dynamic frequency that affects the performance.
I will not this for future. I have removed all the Movenet model and am only using the trt_pose model now.
