Jetpack 5.0.2 Docker Container: cannot run Tensorflow
I just pulled the docker image of the latest Jetpack 5.0.2 version. However, when I try to run Tensorflow I get the following:
nvidia@nvidia-desktop:~$ docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-tensorflow:r35.1.0-tf2.9-py3
root@nvidia-desktop:/# python3
Python 3.8.10 (default, Jun 22 2022, 20:18:18)
[GCC 9.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tensorflow as tf
>>> tf.constant([1,2,3])
2022-10-13 07:59:02.981299: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:977] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
Your kernel may have been built without NUMA support.
2022-10-13 07:59:03.052606: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:977] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-10-13 07:59:03.052847: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:977] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-10-13 07:59:03.055257: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:977] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-10-13 07:59:03.055515: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:977] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
2022-10-13 07:59:03.055685: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:977] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
  File "<stdin>", line 1, in <module>
  File "/usr/local/lib/python3.8/dist-packages/tensorflow/python/framework/constant_op.py", line 267, in constant
    return _constant_impl(value, dtype, shape, name, verify_shape=False,
  File "/usr/local/lib/python3.8/dist-packages/tensorflow/python/framework/constant_op.py", line 279, in _constant_impl
    return _constant_eager_impl(ctx, value, dtype, shape, verify_shape)
  File "/usr/local/lib/python3.8/dist-packages/tensorflow/python/framework/constant_op.py", line 304, in _constant_eager_impl
    t = convert_to_eager_tensor(value, ctx, dtype)
  File "/usr/local/lib/python3.8/dist-packages/tensorflow/python/framework/constant_op.py", line 101, in convert_to_eager_tensor
    ctx.ensure_initialized()
  File "/usr/local/lib/python3.8/dist-packages/tensorflow/python/eager/context.py", line 611, in ensure_initialized
    context_handle = pywrap_tfe.TFE_NewContext(opts)
tensorflow.python.framework.errors_impl.InternalError: cudaGetDevice() failed. Status: initialization error
Searching the web for this error, I find mentions of incompatible CUDA and cuDNN versions, but this surely cannot be the problem as this is running in the official docker container. Have I just done something stupid? Doing the above works just fine in the JetPack 4.6 container. Any advice is appreciated.
Please noted that there are some depedencies between GPU driver and libraries.
Did you setup Jetson with JetPack 5.0.2 as well?
If not, please give it a try.
I’m not used to the Jetson ecosystem, so bear with me. I have a few Jetson AGX Xavier units (not sure of the distinction between development kit and module, but since I can ssh into the device and don’t need to flash the finished software into the device, I assume they are development kits). These have been set up such that I can run the l4t-tensorflow docker containers for JetPack 4.6. Now that I want to run the newer containers for 5.0.2 I need to also update the software on the device, it is not sufficient to change the container, are these (How to Install JetPack :: NVIDIA JetPack Documentation) the correct instructions for this? if I’ve read these instructions correctly they all require physical access to the device? I cannot access our devices physically as they are off-site, is there any way that I could update our devices without being there in person? Thank you.
Please flash the device directly if you want to upgrade from JetPack 4.6 to JetPack 5.0.2.
