Problem when compiling on Linux Mint 9
I’m getting this output every time I try and compile with nvcc on my Mint box. What is __surfxDreadcx and why am I getting this output because of it?
I’ve got the 3.2 toolkit, 3.2 SDK and the current dev driver on this machine. My PATH and LD_LIBRARY_PATH variables are both updated correctly.
/usr/local/cuda/include/surface_functions.h: In function ‘void surf1Dread(T*, surface<void, 1>, int, int, cudaSurfaceBoundaryMode)’:
/usr/local/cuda/include/surface_functions.h:100: error: there are no arguments to ‘__surf1Dreadc1’ that depend on a template parameter, so a declaration of ‘__surf1Dreadc1’ must be available
/usr/local/cuda/include/surface_functions.h:100: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/usr/local/cuda/include/surface_functions.h:101: error: there are no arguments to ‘__surf1Dreads1’ that depend on a template parameter, so a declaration of ‘__surf1Dreads1’ must be available
/usr/local/cuda/include/surface_functions.h:102: error: there are no arguments to ‘__surf1Dreadu1’ that depend on a template parameter, so a declaration of ‘__surf1Dreadu1’ must be available
/usr/local/cuda/include/surface_functions.h:103: error: there are no arguments to ‘__surf1Dreadu2’ that depend on a template parameter, so a declaration of ‘__surf1Dreadu2’ must be available
/usr/local/cuda/include/surface_functions.h:104: error: there are no arguments to ‘__surf1Dreadu4’ that depend on a template parameter, so a declaration of ‘__surf1Dreadu4’ must be available
/usr/local/cuda/include/surface_functions.h: In function ‘void surf2Dread(T*, surface<void, 2>, int, int, int, cudaSurfaceBoundaryMode)’:
/usr/local/cuda/include/surface_functions.h:460: error: there are no arguments to ‘__surf2Dreadc1’ that depend on a template parameter, so a declaration of ‘__surf2Dreadc1’ must be available
/usr/local/cuda/include/surface_functions.h:461: error: there are no arguments to ‘__surf2Dreads1’ that depend on a template parameter, so a declaration of ‘__surf2Dreads1’ must be available
/usr/local/cuda/include/surface_functions.h:462: error: there are no arguments to ‘__surf2Dreadu1’ that depend on a template parameter, so a declaration of ‘__surf2Dreadu1’ must be available
/usr/local/cuda/include/surface_functions.h:463: error: there are no arguments to ‘__surf2Dreadu2’ that depend on a template parameter, so a declaration of ‘__surf2Dreadu2’ must be available
/usr/local/cuda/include/surface_functions.h:464: error: there are no arguments to ‘__surf2Dreadu4’ that depend on a template parameter, so a declaration of ‘__surf2Dreadu4’ must be available
make: *** [obj/x86_64/release/ParticleSystem.cu.o] Error 1
This happens when I try and compile the 3.2 SDK and this rather simple program I’ve whipped up and tried sending through nvcc. Don’t worry, it’s a .cu file.
#include <stdio.h>
__global__ void kernel(void) {
int main(void) {
	kernel<<<1,1>>>();
	printf("Hello World!\n");
	return 0;
#include <stdio.h>
int main(void) {
	kernel<<<1,1>>>();
	return 0;
