Problems with C++ libraries
when compiling my test-programm with nvcc, I get the following error message
run command: nvcc --host-compilation=c++ -deviceemu -run cuda_test.cu,
error message:
[code]
/usr/include/c++/4.3/bits/ios_base.h:409: Fehler: Deklaration von »typedef class std::streampos std::ios_base::streampos«
/usr/include/c++/4.3/bits/postypes.h:207: Fehler: verändert die Bedeutung von »streampos« von »typedef class std::fpos<__mbstate_t> std::streampos«
/usr/include/c++/4.3/bits/ios_base.h:410: Fehler: Deklaration von »typedef std::streamoff std::ios_base::streamoff«
/usr/include/c++/4.3/bits/postypes.h:71: Fehler: verändert die Bedeutung von »streamoff« von »typedef int64_t std::streamoff«
/usr/include/c++/4.3/streambuf:147: Anmerkung: (wenn das nicht beabsichtigt war, sollte sicher gestellt werden, dass das Funktions-Template bereits deklariert wurde, und <> hier hinter Funktionsnamen eingefügt wurde)
[\code]
my test-program:
#include
#include <stdio.h>
#define N 16
global void vecAdd(float* A, float* B, float* C)
int i = threadIdx.x;
C[i] =3;// A[i] + B[i];
int main()
float* a,*b,*c;
float d=3;
float e=3;
a=&d;
b=&e;
c=(float*)malloc(16*sizeof(float));
// Kernel invocation
vecAdd<<<1, N>>>(a,b,c);
//std::cout<<c[0]<<std::endl;
printf(“%d”,(int)c[1]);
I installed a Toolkit 2.1. (but no cuda driver, because my OS isn’t supported by CUDA).
I’m running Kubuntu 9.04 with a gcc 4.3.3 compiler
compiling and running with nvcc works fine with c-code.
Does anybody know what the problem is?
Another thread in this forum (http://forums.nvidia.com/index.php?showtopic=98453&st=0&p=549336&#entry549336) is about compiling with the toolkit 2.2., but I actually have 2.1 installed, which is said to work fine on kubuntu 9.04
Thanks in advance.
Have you try to compile an example c++ code to see if the compiler is working well?
I forgot to ask if you did a downgrade on the compiler.
