Wow generix thanks for this advice!
This solved the BaseMosaic problem (I would have never figured this out by myself).
Now I got the next problem:
although all metamodes are definied in the xorg.conf, the monitor layout of all six monitors is always in one line.
I need following layout:
GPU-0.DP-0.8 GPU-0.DP-2.8
GPU-1.DP-2.8 GPU-1.DP-0.8 GPU-1.DP-4.8 GPU-1.DP-6.8
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 515.65.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
Option "StandbyTime" "0"
Option "SuspendTime" "0"
Option "OffTime" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "HPN HP Z27q G3"
HorizSync 30.0 - 90.0
VertRefresh 50.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA T600"
BusID "PCI:33:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2.8"
Option "metamodes" "GPU-0.DP-0.8: nvidia-auto-select +2560+0, GPU-0.DP-2.8: nvidia-auto-select +0+0, GPU-1.DP-2.8: nvidia-auto-select +0+1440, GPU-1.DP-0.8: nvidia-auto-select +2560+1440, GPU-1.DP-4.8: nvidia-auto-select +7680+1440, GPU-1.DP-6.8: nvidia-auto-select +5120+1440"
Option "MultiGPU" "Off"
Option "SLI" "off"
Option "BaseMosaic" "on"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Log:
[ 4094.634] (--) Log file renamed from "/var/lib/gdm/.local/share/xorg/Xorg.pid-12087.log" to "/var/lib/gdm/.local/share/xorg/Xorg.0.log"
[ 4094.634]
X.Org X Server 1.20.3
X Protocol Version 11, Revision 0
[ 4094.634] Build Operating System: openSUSE SUSE LINUX
[ 4094.634] Current Operating System: Linux rmrgoar21l 5.3.18-150300.59.98-default #1 SMP Thu Oct 13 08:52:00 UTC 2022 (dfcde7e) x86_64
[ 4094.634] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.3.18-150300.59.98-default root=/dev/mapper/vgsystem-lv_root hpsa.hpsa_allow_any=1 YAST_SKIP_XML_VALIDATION=1 resume=/dev/md0p1 splash=silent quiet showopts apparmor=1 security=apparmor mitigations=auto
[ 4094.634] Build Date: 19 October 2022 12:00:00PM
[ 4094.634]
[ 4094.634] Current version of pixman: 0.34.0
[ 4094.634] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 4094.634] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 4094.634] (==) Log file: "/var/lib/gdm/.local/share/xorg/Xorg.0.log", Time: Fri Nov 18 12:48:10 2022
[ 4094.635] (==) Using config file: "/etc/X11/xorg.conf"
[ 4094.635] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 4094.635] (==) ServerLayout "Layout0"
[ 4094.635] (**) |-->Screen "Screen0" (0)
[ 4094.635] (**) | |-->Monitor "Monitor0"
[ 4094.635] (**) | |-->Device "Device0"
[ 4094.635] (**) |-->Input Device "Keyboard0"
[ 4094.635] (**) |-->Input Device "Mouse0"
[ 4094.635] (**) Option "StandbyTime" "0"
[ 4094.635] (**) Option "SuspendTime" "0"
[ 4094.635] (**) Option "OffTime" "0"
[ 4094.636] (**) Option "Xinerama" "0"
[ 4094.636] (==) Automatically adding devices
[ 4094.636] (==) Automatically enabling devices
[ 4094.636] (==) Automatically adding GPU devices
[ 4094.636] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4094.636] (WW) The directory "/usr/share/fonts/ghostscript/" does not exist.
[ 4094.636] Entry deleted from font path.
[ 4094.636] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[ 4094.636] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 4094.636] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 4094.636] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 4094.636] (WW) Disabling Keyboard0
[ 4094.636] (WW) Disabling Mouse0
[ 4094.636] (II) Loader magic: 0x55ec08f83d20
[ 4094.636] (II) Module ABI versions:
[ 4094.636] X.Org ANSI C Emulation: 0.4
[ 4094.636] X.Org Video Driver: 24.0
[ 4094.636] X.Org XInput driver : 24.1
[ 4094.636] X.Org Server Extension : 10.0
[ 4094.637] (++) using VT number 7
[ 4094.639] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c9
[ 4094.640] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4094.641] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 4094.641] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 4094.642] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 4094.660] (--) PCI: (21@0:0:0) 10de:1fb1:103c:1488 rev 161, Mem @ 0xab000000/16777216, 0x387fe0000000/268435456, 0x387ff0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 4094.660] (--) PCI:*(33@0:0:0) 10de:1fb1:103c:1488 rev 161, Mem @ 0xc6000000/16777216, 0x38bfe0000000/268435456, 0x38bff0000000/33554432, I/O @ 0x00008000/128, BIOS @ 0x????????/524288
[ 4094.660] (II) LoadModule: "glx"
[ 4094.660] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 4094.661] (II) Module glx: vendor="X.Org Foundation"
[ 4094.661] compiled for 1.20.3, module version = 1.0.0
[ 4094.661] ABI class: X.Org Server Extension, version 10.0
[ 4094.661] (II) LoadModule: "nvidia"
[ 4094.661] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 4094.661] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 4094.661] compiled for 1.6.99.901, module version = 1.0.0
[ 4094.661] Module class: X.Org Video Driver
[ 4094.661] (II) NVIDIA dlloader X Driver 515.65.01 Wed Jul 20 13:50:46 UTC 2022
[ 4094.661] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 4094.661] (II) systemd-logind: releasing fd for 226:1
[ 4094.662] (II) Loading sub module "fb"
[ 4094.662] (II) LoadModule: "fb"
[ 4094.662] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 4094.662] (II) Module fb: vendor="X.Org Foundation"
[ 4094.662] compiled for 1.20.3, module version = 1.0.0
[ 4094.662] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4094.662] (II) Loading sub module "wfb"
[ 4094.662] (II) LoadModule: "wfb"
[ 4094.662] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 4094.663] (II) Module wfb: vendor="X.Org Foundation"
[ 4094.663] compiled for 1.20.3, module version = 1.0.0
[ 4094.663] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4094.663] (II) Loading sub module "ramdac"
[ 4094.663] (II) LoadModule: "ramdac"
[ 4094.663] (II) Module "ramdac" already built-in
[ 4094.663] (II) systemd-logind: releasing fd for 226:0
[ 4094.664] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 4094.664] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 4094.664] (==) NVIDIA(0): RGB weight 888
[ 4094.664] (==) NVIDIA(0): Default visual is TrueColor
[ 4094.664] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 4094.664] (**) NVIDIA(0): Option "Stereo" "0"
[ 4094.664] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-2.8"
[ 4094.664] (**) NVIDIA(0): Option "SLI" "off"
[ 4094.664] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 4094.664] (**) NVIDIA(0): Option "BaseMosaic" "on"
[ 4094.664] (**) NVIDIA(0): Stereo disabled by request
[ 4094.664] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 4094.664] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 4094.664] (**) NVIDIA(0): Option "MetaModes" "GPU-0.DP-0.8: nvidia-auto-select +2560+0, GPU-0.DP-2.8: nvidia-auto-select +0+0, GPU-1.DP-2.8: nvidia-auto-select +0+1440, GPU-1.DP-0.8: nvidia-auto-select +2560+1440, GPU-1.DP-4.8: nvidia-auto-select +7680+1440, GPU-1.DP-6.8: nvidia-auto-select +5120+1440"
[ 4094.664] (**) NVIDIA(0): Enabling 2D acceleration
[ 4094.664] (II) Loading sub module "glxserver_nvidia"
[ 4094.664] (II) LoadModule: "glxserver_nvidia"
[ 4094.664] (II) Loading /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so
[ 4094.672] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 4094.672] compiled for 1.6.99.901, module version = 1.0.0
[ 4094.672] Module class: X.Org Server Extension
[ 4094.672] (II) NVIDIA GLX Module 515.65.01 Wed Jul 20 13:48:42 UTC 2022
[ 4094.672] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 4096.679] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[ 4101.326] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:33:0:0
[ 4101.327] (--) NVIDIA(0): DFP-0.8
[ 4101.327] (--) NVIDIA(0): DFP-2.8
[ 4101.327] (--) NVIDIA(0): DFP-0 (boot)
[ 4101.327] (--) NVIDIA(0): DFP-1
[ 4101.327] (--) NVIDIA(0): DFP-2 (boot)
[ 4101.327] (--) NVIDIA(0): DFP-3
[ 4101.327] (--) NVIDIA(0): DFP-4
[ 4101.327] (--) NVIDIA(0): DFP-5
[ 4101.327] (--) NVIDIA(0): DFP-6
[ 4101.327] (--) NVIDIA(0): DFP-7
[ 4101.327] (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:21:0:0
[ 4101.327] (--) NVIDIA(0): DFP-4.8
[ 4101.327] (--) NVIDIA(0): DFP-6.8
[ 4101.332] (II) NVIDIA(0): NVIDIA GPU NVIDIA T600 (TU117GL-A) at PCI:33:0:0 (GPU-0)
[ 4101.332] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 4101.332] (--) NVIDIA(0): VideoBIOS: 90.17.76.00.26
[ 4101.332] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 4101.332] (II) NVIDIA(0): NVIDIA GPU NVIDIA T600 (TU117GL-A) at PCI:21:0:0 (GPU-1)
[ 4101.332] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): connected
[ 4101.332] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4101.332] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41D3-1D54000000F3
[ 4101.332] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4101.333] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): connected
[ 4101.333] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4101.333] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-41AA-578E00000060
[ 4101.333] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4101.333] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4101.333] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 4101.333] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 4101.336] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4101.336] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 4101.336] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 4101.336] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 4101.336] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 4101.336] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 4101.339] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 4101.339] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 4101.339] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 4101.339] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4101.339] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 4101.339] (--) NVIDIA(GPU-0): DFP-4: 2660.0 MHz maximum pixel clock
[ 4101.339] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 4101.339] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 4101.339] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 4101.339] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 4101.339] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 4101.339] (--) NVIDIA(GPU-0): DFP-6: 2660.0 MHz maximum pixel clock
[ 4101.339] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 4101.339] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 4101.339] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 4101.339] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): connected
[ 4101.339] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4101.339] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-4195-DFCC000000F8
[ 4101.339] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): connected
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): Internal DisplayPort
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): GUID: 10DE9070-0005-EDA7-41AE-1869000000D8
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): 2660.0 MHz maximum pixel clock
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): connected
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): Internal DisplayPort
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): GUID: 10DE9070-0005-EDA7-41AE-576100000038
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): 2660.0 MHz maximum pixel clock
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): connected
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41AD-B26E00000050
[ 4101.340] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4101.340] (--) NVIDIA(GPU-1): DFP-0: disconnected
[ 4101.340] (--) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 4101.340] (--) NVIDIA(GPU-1): DFP-0: 2660.0 MHz maximum pixel clock
[ 4101.343] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 4101.343] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 4101.343] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 4101.343] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 4101.343] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 4101.343] (--) NVIDIA(GPU-1): DFP-2: 2660.0 MHz maximum pixel clock
[ 4101.346] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 4101.346] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 4101.346] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 4101.346] (--) NVIDIA(GPU-1): DFP-4: disconnected
[ 4101.346] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 4101.346] (--) NVIDIA(GPU-1): DFP-4: 2660.0 MHz maximum pixel clock
[ 4101.349] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 4101.349] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 4101.349] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 4101.349] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 4101.349] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 4101.349] (--) NVIDIA(GPU-1): DFP-6: 2660.0 MHz maximum pixel clock
[ 4101.352] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 4101.352] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 4101.352] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 4101.564] (II) NVIDIA(0): Validated MetaModes:
[ 4101.564] (II) NVIDIA(0): "GPU-0.DP-0.8:nvidia-auto-select+2560+0,GPU-0.DP-2.8:nvidia-auto-select+0+0,GPU-1.DP-2.8:nvidia-auto-select+0+1440,GPU-1.DP-0.8:nvidia-auto-select+2560+1440,GPU-1.DP-4.8:nvidia-auto-select+7680+1440,GPU-1.DP-6.8:nvidia-auto-select+5120+1440"
[ 4101.564] (II) NVIDIA(0): Virtual screen size determined to be 10240 x 2880
[ 4101.606] (--) NVIDIA(0): DPI set to (108, 107); computed from "UseEdidDpi" X config
[ 4101.606] (--) NVIDIA(0): option
[ 4101.606] (II) NVIDIA(G0): NVIDIA T600 (GPU-1) already has an X screen assigned; skipping
[ 4101.606] (II) NVIDIA(G0): this GPU screen
[ 4101.606] (EE) NVIDIA(G0): Failing initialization of X screen
[ 4101.607] (II) UnloadModule: "nvidia"
[ 4101.607] (II) UnloadSubModule: "wfb"
[ 4101.607] (II) UnloadSubModule: "fb"
[ 4101.607] (WW) NVIDIA: Failed to bind sideband socket to
[ 4101.607] (WW) NVIDIA: '/var/run/nvidia-xdriver-fc0b5eda' Permission denied
[ 4101.607] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 4101.607] (II) NVIDIA: access.
[ 4101.611] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 4101.611] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 4101.611] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 4101.611] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 4101.611] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 4101.611] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 4101.611] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 4101.611] (II) NVIDIA(0): Config Options in the README.
[ 4101.631] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8:nvidia-auto-select+2560+0,GPU-0.DP-2.8:nvidia-auto-select+0+0,GPU-1.DP-2.8:nvidia-auto-select+0+1440,GPU-1.DP-0.8:nvidia-auto-select+2560+1440,GPU-1.DP-4.8:nvidia-auto-select+7680+1440,GPU-1.DP-6.8:nvidia-auto-select+5120+1440"
[ 4102.086] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 4102.086] (==) NVIDIA(0): Backing store enabled
[ 4102.086] (==) NVIDIA(0): Silken mouse enabled
[ 4102.086] (**) NVIDIA(0): DPMS enabled
[ 4102.087] (II) Loading sub module "dri2"
[ 4102.087] (II) LoadModule: "dri2"
[ 4102.087] (II) Module "dri2" already built-in
[ 4102.087] (II) NVIDIA(0): [DRI2] Setup complete
[ 4102.087] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 4102.087] (II) Initializing extension Generic Event Extension
[ 4102.087] (II) Initializing extension SHAPE
[ 4102.087] (II) Initializing extension MIT-SHM
[ 4102.087] (II) Initializing extension XInputExtension
[ 4102.087] (II) Initializing extension XTEST
[ 4102.087] (II) Initializing extension BIG-REQUESTS
[ 4102.087] (II) Initializing extension SYNC
[ 4102.088] (II) Initializing extension XKEYBOARD
[ 4102.088] (II) Initializing extension XC-MISC
[ 4102.088] (II) Initializing extension SECURITY
[ 4102.088] (II) Initializing extension XFIXES
[ 4102.088] (II) Initializing extension RENDER
[ 4102.088] (II) Initializing extension RANDR
[ 4102.088] (II) Initializing extension COMPOSITE
[ 4102.088] (II) Initializing extension DAMAGE
[ 4102.089] (II) Initializing extension MIT-SCREEN-SAVER
[ 4102.089] (II) Initializing extension DOUBLE-BUFFER
[ 4102.089] (II) Initializing extension RECORD
[ 4102.089] (II) Initializing extension DPMS
[ 4102.089] (II) Initializing extension Present
[ 4102.089] (II) Initializing extension DRI3
[ 4102.089] (II) Initializing extension X-Resource
[ 4102.089] (II) Initializing extension XVideo
[ 4102.089] (II) Initializing extension XVideo-MotionCompensation
[ 4102.089] (II) Initializing extension GLX
[ 4102.089] (II) Indirect GLX disabled.
[ 4102.089] (II) GLX: Another vendor is already registered for screen 0
[ 4102.089] (II) Initializing extension XFree86-VidModeExtension
[ 4102.090] (II) Initializing extension XFree86-DGA
[ 4102.090] (II) Initializing extension XFree86-DRI
[ 4102.090] (II) Initializing extension DRI2
[ 4102.090] (II) Initializing extension NV-GLX
[ 4102.090] (II) Initializing extension NV-CONTROL
[ 4102.090] (II) Initializing extension XINERAMA
[ 4102.135] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[ 4102.135] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4102.135] (II) LoadModule: "evdev"
[ 4102.135] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 4102.135] (II) Module evdev: vendor="X.Org Foundation"
[ 4102.135] compiled for 1.20.3, module version = 2.10.6
[ 4102.135] Module class: X.Org XInput Driver
[ 4102.135] ABI class: X.Org XInput driver, version 24.1
[ 4102.135] (II) Using input driver 'evdev' for 'Power Button'
[ 4102.136] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 42 paused 0
[ 4102.136] (**) Power Button: always reports core events
[ 4102.136] (**) evdev: Power Button: Device: "/dev/input/event6"
[ 4102.136] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 4102.136] (--) evdev: Power Button: Found keys
[ 4102.136] (II) evdev: Power Button: Configuring as keyboard
[ 4102.136] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input9/event6"
[ 4102.136] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 4102.136] (**) Option "xkb_rules" "evdev"
[ 4102.136] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[ 4102.136] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4102.136] (II) Using input driver 'evdev' for 'Power Button'
[ 4102.137] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 43 paused 0
[ 4102.137] (**) Power Button: always reports core events
[ 4102.137] (**) evdev: Power Button: Device: "/dev/input/event5"
[ 4102.137] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 4102.137] (--) evdev: Power Button: Found keys
[ 4102.137] (II) evdev: Power Button: Configuring as keyboard
[ 4102.137] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input8/event5"
[ 4102.137] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 4102.137] (**) Option "xkb_rules" "evdev"
[ 4102.138] (II) config/udev: Adding input device Chicony HP Business Slim Keyboard (/dev/input/event0)
[ 4102.138] (**) Chicony HP Business Slim Keyboard: Applying InputClass "evdev keyboard catchall"
[ 4102.138] (II) Using input driver 'evdev' for 'Chicony HP Business Slim Keyboard'
[ 4102.138] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 44 paused 0
[ 4102.138] (**) Chicony HP Business Slim Keyboard: always reports core events
[ 4102.138] (**) evdev: Chicony HP Business Slim Keyboard: Device: "/dev/input/event0"
[ 4102.138] (--) evdev: Chicony HP Business Slim Keyboard: Vendor 0x3f0 Product 0x304a
[ 4102.138] (--) evdev: Chicony HP Business Slim Keyboard: Found keys
[ 4102.138] (II) evdev: Chicony HP Business Slim Keyboard: Configuring as keyboard
[ 4102.138] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/0003:03F0:304A.0001/input/input3/event0"
[ 4102.138] (II) XINPUT: Adding extended input device "Chicony HP Business Slim Keyboard" (type: KEYBOARD, id 8)
[ 4102.138] (**) Option "xkb_rules" "evdev"
[ 4102.139] (II) config/udev: Adding input device Chicony HP Business Slim Keyboard Consumer Control (/dev/input/event1)
[ 4102.139] (**) Chicony HP Business Slim Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 4102.139] (II) Using input driver 'evdev' for 'Chicony HP Business Slim Keyboard Consumer Control'
[ 4102.140] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 45 paused 0
[ 4102.140] (**) Chicony HP Business Slim Keyboard Consumer Control: always reports core events
[ 4102.140] (**) evdev: Chicony HP Business Slim Keyboard Consumer Control: Device: "/dev/input/event1"
[ 4102.140] (--) evdev: Chicony HP Business Slim Keyboard Consumer Control: Vendor 0x3f0 Product 0x304a
[ 4102.140] (--) evdev: Chicony HP Business Slim Keyboard Consumer Control: Found 1 mouse buttons
[ 4102.140] (--) evdev: Chicony HP Business Slim Keyboard Consumer Control: Found scroll wheel(s)
[ 4102.140] (--) evdev: Chicony HP Business Slim Keyboard Consumer Control: Found relative axes
[ 4102.140] (II) evdev: Chicony HP Business Slim Keyboard Consumer Control: Forcing relative x/y axes to exist.
[ 4102.140] (--) evdev: Chicony HP Business Slim Keyboard Consumer Control: Found absolute axes
[ 4102.140] (II) evdev: Chicony HP Business Slim Keyboard Consumer Control: Forcing absolute x/y axes to exist.
[ 4102.140] (--) evdev: Chicony HP Business Slim Keyboard Consumer Control: Found keys
[ 4102.140] (II) evdev: Chicony HP Business Slim Keyboard Consumer Control: Configuring as mouse
[ 4102.140] (II) evdev: Chicony HP Business Slim Keyboard Consumer Control: Configuring as keyboard
[ 4102.140] (II) evdev: Chicony HP Business Slim Keyboard Consumer Control: Adding scrollwheel support
[ 4102.140] (**) evdev: Chicony HP Business Slim Keyboard Consumer Control: YAxisMapping: buttons 4 and 5
[ 4102.140] (**) evdev: Chicony HP Business Slim Keyboard Consumer Control: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 4102.140] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.1/0003:03F0:304A.0002/input/input4/event1"
[ 4102.140] (II) XINPUT: Adding extended input device "Chicony HP Business Slim Keyboard Consumer Control" (type: KEYBOARD, id 9)
[ 4102.140] (**) Option "xkb_rules" "evdev"
[ 4102.140] (II) evdev: Chicony HP Business Slim Keyboard Consumer Control: initialized for relative axes.
[ 4102.140] (WW) evdev: Chicony HP Business Slim Keyboard Consumer Control: ignoring absolute axes.
[ 4102.140] (**) Chicony HP Business Slim Keyboard Consumer Control: (accel) keeping acceleration scheme 1
[ 4102.140] (**) Chicony HP Business Slim Keyboard Consumer Control: (accel) acceleration profile 0
[ 4102.140] (**) Chicony HP Business Slim Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 4102.140] (**) Chicony HP Business Slim Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 4102.141] (II) config/udev: Adding input device Chicony HP Business Slim Keyboard System Control (/dev/input/event2)
[ 4102.141] (**) Chicony HP Business Slim Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 4102.141] (II) Using input driver 'evdev' for 'Chicony HP Business Slim Keyboard System Control'
[ 4102.141] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 46 paused 0
[ 4102.141] (**) Chicony HP Business Slim Keyboard System Control: always reports core events
[ 4102.141] (**) evdev: Chicony HP Business Slim Keyboard System Control: Device: "/dev/input/event2"
[ 4102.141] (--) evdev: Chicony HP Business Slim Keyboard System Control: Vendor 0x3f0 Product 0x304a
[ 4102.141] (--) evdev: Chicony HP Business Slim Keyboard System Control: Found keys
[ 4102.141] (II) evdev: Chicony HP Business Slim Keyboard System Control: Configuring as keyboard
[ 4102.141] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.1/0003:03F0:304A.0002/input/input5/event2"
[ 4102.141] (II) XINPUT: Adding extended input device "Chicony HP Business Slim Keyboard System Control" (type: KEYBOARD, id 10)
[ 4102.141] (**) Option "xkb_rules" "evdev"
[ 4102.142] (II) config/udev: Adding input device Chicony HP Business Slim Keyboard (/dev/input/event3)
[ 4102.142] (**) Chicony HP Business Slim Keyboard: Applying InputClass "evdev keyboard catchall"
[ 4102.142] (II) Using input driver 'evdev' for 'Chicony HP Business Slim Keyboard'
[ 4102.143] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 47 paused 0
[ 4102.143] (**) Chicony HP Business Slim Keyboard: always reports core events
[ 4102.143] (**) evdev: Chicony HP Business Slim Keyboard: Device: "/dev/input/event3"
[ 4102.143] (--) evdev: Chicony HP Business Slim Keyboard: Vendor 0x3f0 Product 0x304a
[ 4102.143] (--) evdev: Chicony HP Business Slim Keyboard: Found keys
[ 4102.143] (II) evdev: Chicony HP Business Slim Keyboard: Configuring as keyboard
[ 4102.143] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.1/0003:03F0:304A.0002/input/input6/event3"
[ 4102.143] (II) XINPUT: Adding extended input device "Chicony HP Business Slim Keyboard" (type: KEYBOARD, id 11)
[ 4102.143] (**) Option "xkb_rules" "evdev"
[ 4102.143] (II) config/udev: Adding input device PixArt HP USB Optical Mouse (/dev/input/event4)
[ 4102.143] (**) PixArt HP USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 4102.143] (II) Using input driver 'evdev' for 'PixArt HP USB Optical Mouse'
[ 4102.144] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 48 paused 0
[ 4102.144] (**) PixArt HP USB Optical Mouse: always reports core events
[ 4102.144] (**) evdev: PixArt HP USB Optical Mouse: Device: "/dev/input/event4"
[ 4102.144] (--) evdev: PixArt HP USB Optical Mouse: Vendor 0x3f0 Product 0x1f4a
[ 4102.144] (--) evdev: PixArt HP USB Optical Mouse: Found 3 mouse buttons
[ 4102.144] (--) evdev: PixArt HP USB Optical Mouse: Found scroll wheel(s)
[ 4102.144] (--) evdev: PixArt HP USB Optical Mouse: Found relative axes
[ 4102.144] (--) evdev: PixArt HP USB Optical Mouse: Found x and y relative axes
[ 4102.144] (II) evdev: PixArt HP USB Optical Mouse: Configuring as mouse
[ 4102.144] (II) evdev: PixArt HP USB Optical Mouse: Adding scrollwheel support
[ 4102.144] (**) evdev: PixArt HP USB Optical Mouse: YAxisMapping: buttons 4 and 5
[ 4102.144] (**) evdev: PixArt HP USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 4102.144] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.0/0003:03F0:1F4A.0003/input/input7/event4"
[ 4102.144] (II) XINPUT: Adding extended input device "PixArt HP USB Optical Mouse" (type: MOUSE, id 12)
[ 4102.144] (II) evdev: PixArt HP USB Optical Mouse: initialized for relative axes.
[ 4102.144] (**) PixArt HP USB Optical Mouse: (accel) keeping acceleration scheme 1
[ 4102.144] (**) PixArt HP USB Optical Mouse: (accel) acceleration profile 0
[ 4102.144] (**) PixArt HP USB Optical Mouse: (accel) acceleration factor: 2.000
[ 4102.144] (**) PixArt HP USB Optical Mouse: (accel) acceleration threshold: 4
[ 4102.145] (II) config/udev: Adding input device PixArt HP USB Optical Mouse (/dev/input/mouse0)
[ 4102.145] (II) No input driver specified, ignoring this device.
[ 4102.145] (II) This device may have been added with another device file.
[ 4102.145] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event23)
[ 4102.145] (II) config/udev: Adding input device HDA Intel PCH Headset Mic (/dev/input/event24)
[ 4102.145] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event25)
[ 4102.146] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event26)
[ 4102.146] (II) No input driver specified, ignoring this device.
[ 4102.146] (II) This device may have been added with another device file.
[ 4102.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event16)
[ 4102.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event17)
[ 4102.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event18)
[ 4102.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event19)
[ 4102.147] (II) No input driver specified, ignoring this device.
[ 4102.147] (II) This device may have been added with another device file.
[ 4102.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event20)
[ 4102.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event21)
[ 4102.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event22)
[ 4102.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 4102.148] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[ 4102.148] (II) No input driver specified, ignoring this device.
[ 4102.148] (II) This device may have been added with another device file.
[ 4102.148] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[ 4102.148] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[ 4102.148] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event13)
[ 4102.149] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event14)
[ 4102.149] (II) No input driver specified, ignoring this device.
[ 4102.149] (II) This device may have been added with another device file.
[ 4102.149] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event15)
[ 4102.149] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 4102.150] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event8)
[ 4102.150] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 4102.150] (II) Using input driver 'evdev' for 'HP WMI hotkeys'
[ 4102.151] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 49 paused 0
[ 4102.151] (**) HP WMI hotkeys: always reports core events
[ 4102.151] (**) evdev: HP WMI hotkeys: Device: "/dev/input/event8"
[ 4102.151] (--) evdev: HP WMI hotkeys: Vendor 0 Product 0
[ 4102.151] (--) evdev: HP WMI hotkeys: Found keys
[ 4102.151] (II) evdev: HP WMI hotkeys: Configuring as keyboard
[ 4102.151] (**) Option "config_info" "udev:/sys/devices/virtual/input/input11/event8"
[ 4102.151] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 13)
[ 4102.151] (**) Option "xkb_rules" "evdev"
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): connected
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-4195-DFCC000000F8
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): connected
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): Internal DisplayPort
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): GUID: 10DE9070-0005-EDA7-41AE-1869000000D8
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): 2660.0 MHz maximum pixel clock
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): connected
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): Internal DisplayPort
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): GUID: 10DE9070-0005-EDA7-41AE-576100000038
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): 2660.0 MHz maximum pixel clock
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): connected
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41AD-B26E00000050
[ 4102.154] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): connected
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41D3-1D54000000F3
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): connected
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-41AA-578E00000060
[ 4102.154] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4102.455] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): connected
[ 4102.455] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4102.455] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41D3-1D54000000F3
[ 4102.455] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4102.456] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): connected
[ 4102.456] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4102.456] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-41AA-578E00000060
[ 4102.456] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4102.456] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4102.456] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 4102.456] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 4102.459] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4102.459] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 4102.459] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 4102.459] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 4102.459] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 4102.459] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 4102.462] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 4102.462] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 4102.462] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 4102.462] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4102.462] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 4102.462] (--) NVIDIA(GPU-0): DFP-4: 2660.0 MHz maximum pixel clock
[ 4102.462] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 4102.462] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 4102.462] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 4102.462] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 4102.462] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 4102.462] (--) NVIDIA(GPU-0): DFP-6: 2660.0 MHz maximum pixel clock
[ 4102.462] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 4102.462] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 4102.462] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): connected
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-4195-DFCC000000F8
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): connected
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): Internal DisplayPort
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): GUID: 10DE9070-0005-EDA7-41AE-1869000000D8
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): 2660.0 MHz maximum pixel clock
[ 4102.463] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): connected
[ 4102.464] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): Internal DisplayPort
[ 4102.464] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): GUID: 10DE9070-0005-EDA7-41AE-576100000038
[ 4102.464] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): 2660.0 MHz maximum pixel clock
[ 4102.464] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): connected
[ 4102.464] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4102.464] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41AD-B26E00000050
[ 4102.464] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4102.464] (--) NVIDIA(GPU-1): DFP-0: disconnected
[ 4102.464] (--) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 4102.464] (--) NVIDIA(GPU-1): DFP-0: 2660.0 MHz maximum pixel clock
[ 4102.467] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 4102.467] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 4102.467] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 4102.467] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 4102.467] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 4102.467] (--) NVIDIA(GPU-1): DFP-2: 2660.0 MHz maximum pixel clock
[ 4102.470] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 4102.470] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 4102.470] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 4102.470] (--) NVIDIA(GPU-1): DFP-4: disconnected
[ 4102.470] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 4102.470] (--) NVIDIA(GPU-1): DFP-4: 2660.0 MHz maximum pixel clock
[ 4102.473] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 4102.473] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 4102.473] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 4102.473] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 4102.473] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 4102.473] (--) NVIDIA(GPU-1): DFP-6: 2660.0 MHz maximum pixel clock
[ 4102.476] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 4102.476] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 4102.476] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 4102.670] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-2.8: nvidia-auto-select @2560x1440 +0+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-4.8: nvidia-auto-select @2560x1440 +7680+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-6.8: nvidia-auto-select @2560x1440 +5120+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4103.406] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-4.8: nvidia-auto-select @2560x1440 +7680+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-6.8: nvidia-auto-select @2560x1440 +5120+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4104.063] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-6.8: nvidia-auto-select @2560x1440 +5120+1440 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4104.610] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4105.071] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-0.8: nvidia-auto-select @2560x1440 +5120+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4105.492] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-2.8: nvidia-auto-select @2560x1440 +7680+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-0.8: nvidia-auto-select @2560x1440 +5120+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4106.079] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-2.8: nvidia-auto-select @2560x1440 +7680+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-0.8: nvidia-auto-select @2560x1440 +5120+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-4.8: nvidia-auto-select @2560x1440 +10240+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4106.766] (II) NVIDIA(0): Setting mode "GPU-0.DP-0.8: nvidia-auto-select @2560x1440 +2560+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-0.DP-2.8: nvidia-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-2.8: nvidia-auto-select @2560x1440 +7680+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-0.8: nvidia-auto-select @2560x1440 +5120+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-4.8: nvidia-auto-select @2560x1440 +10240+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, GPU-1.DP-6.8: nvidia-auto-select @2560x1440 +12800+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[ 4108.123] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): connected
[ 4108.123] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4108.123] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41D3-1D54000000F3
[ 4108.123] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4108.123] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): connected
[ 4108.123] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4108.123] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-41AA-578E00000060
[ 4108.124] (--) NVIDIA(GPU-0): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4108.124] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 4108.124] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 4108.124] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 4108.126] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 4108.126] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 4108.126] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 4108.127] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 4108.127] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 4108.127] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 4108.129] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 4108.129] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 4108.129] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 4108.129] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 4108.129] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[ 4108.130] (--) NVIDIA(GPU-0): DFP-4: 2660.0 MHz maximum pixel clock
[ 4108.130] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 4108.130] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 4108.130] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 4108.130] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 4108.130] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 4108.130] (--) NVIDIA(GPU-0): DFP-6: 2660.0 MHz maximum pixel clock
[ 4108.130] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 4108.130] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 4108.130] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): connected
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): Internal DisplayPort
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): GUID: 10DE9070-0005-EDA7-4195-DFCC000000F8
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-2.8): 2660.0 MHz maximum pixel clock
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): connected
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): Internal DisplayPort
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): GUID: 10DE9070-0005-EDA7-41AE-1869000000D8
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-4.8): 2660.0 MHz maximum pixel clock
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): connected
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): Internal DisplayPort
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): GUID: 10DE9070-0005-EDA7-41AE-576100000038
[ 4108.130] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-6.8): 2660.0 MHz maximum pixel clock
[ 4108.131] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): connected
[ 4108.131] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): Internal DisplayPort
[ 4108.131] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): GUID: 10DE9070-0005-EDA7-41AD-B26E00000050
[ 4108.131] (--) NVIDIA(GPU-1): HPN HP Z27q G3 (DFP-0.8): 2660.0 MHz maximum pixel clock
[ 4108.131] (--) NVIDIA(GPU-1): DFP-0: disconnected
[ 4108.131] (--) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
[ 4108.131] (--) NVIDIA(GPU-1): DFP-0: 2660.0 MHz maximum pixel clock
[ 4108.134] (--) NVIDIA(GPU-1): DFP-1: disconnected
[ 4108.134] (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
[ 4108.134] (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
[ 4108.134] (--) NVIDIA(GPU-1): DFP-2: disconnected
[ 4108.134] (--) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
[ 4108.134] (--) NVIDIA(GPU-1): DFP-2: 2660.0 MHz maximum pixel clock
[ 4108.137] (--) NVIDIA(GPU-1): DFP-3: disconnected
[ 4108.137] (--) NVIDIA(GPU-1): DFP-3: Internal TMDS
[ 4108.137] (--) NVIDIA(GPU-1): DFP-3: 165.0 MHz maximum pixel clock
[ 4108.137] (--) NVIDIA(GPU-1): DFP-4: disconnected
[ 4108.137] (--) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
[ 4108.137] (--) NVIDIA(GPU-1): DFP-4: 2660.0 MHz maximum pixel clock
[ 4108.139] (--) NVIDIA(GPU-1): DFP-5: disconnected
[ 4108.139] (--) NVIDIA(GPU-1): DFP-5: Internal TMDS
[ 4108.139] (--) NVIDIA(GPU-1): DFP-5: 165.0 MHz maximum pixel clock
[ 4108.139] (--) NVIDIA(GPU-1): DFP-6: disconnected
[ 4108.139] (--) NVIDIA(GPU-1): DFP-6: Internal DisplayPort
[ 4108.139] (--) NVIDIA(GPU-1): DFP-6: 2660.0 MHz maximum pixel clock
[ 4108.142] (--) NVIDIA(GPU-1): DFP-7: disconnected
[ 4108.142] (--) NVIDIA(GPU-1): DFP-7: Internal TMDS
[ 4108.142] (--) NVIDIA(GPU-1): DFP-7: 165.0 MHz maximum pixel clock
[ 4135.070] (II) systemd-logind: got pause for 13:65
[ 4135.070] (II) systemd-logind: got pause for 13:72
[ 4135.070] (II) systemd-logind: got pause for 13:66
[ 4135.070] (II) systemd-logind: got pause for 13:70
[ 4135.070] (II) systemd-logind: got pause for 13:67
[ 4135.070] (II) systemd-logind: got pause for 13:69
[ 4135.070] (II) systemd-logind: got pause for 13:68
[ 4135.070] (II) systemd-logind: got pause for 13:64
Any ideas?
Greets.
