Did it but the system crashed again.
Nov 27 11:30:33 localhost kernel: usercopy: Kernel memory overwrite attempt detected to SLUB object 'nvidia_stack_cache' (offset 12244, size 4)!
Nov 27 11:30:33 localhost kernel: ------------[ cut here ]------------
Nov 27 11:30:33 localhost kernel: kernel BUG at mm/usercopy.c:102!
Nov 27 11:30:33 localhost kernel: invalid opcode: 0000 [#1] SMP NOPTI
Nov 27 11:30:33 localhost kernel: CPU: 0 PID: 875 Comm: Xorg Tainted: P OE 4.19.0-6-amd64 #1 Debian 4.19.67-2+deb10u2
Nov 27 11:30:33 localhost kernel: Hardware name: System manufacturer System Product Name/ROG STRIX X570-E GAMING, BIOS 1404 11/08/2019
Nov 27 11:30:33 localhost kernel: RIP: 0010:usercopy_abort+0x74/0x76
Nov 27 11:30:33 localhost kernel: Code: 0f 45 c6 51 48 89 f9 48 c7 c2 24 7e 87 82 41 52 48 c7 c6 55 6f 86 82 48 c7 c7 f0 7e 87 82 48 0f 45 f2 48 89 c2 e8 a1 2d e8 ff <0f> 0b 49 89 e8 31 c9 44 89 e2 31 f6 48 c7 c7 58 7e 87 82 e8 74 ff
Nov 27 11:30:33 localhost kernel: RSP: 0018:ffffb4e80a0cfca8 EFLAGS: 00010246
Nov 27 11:30:33 localhost kernel: RAX: 000000000000006e RBX: ffff8fdeea21afd4 RCX: 0000000000000000
Nov 27 11:30:33 localhost kernel: RDX: 0000000000000000 RSI: ffff8fdeee8166b8 RDI: ffff8fdeee8166b8
Nov 27 11:30:33 localhost kernel: RBP: 0000000000000004 R08: 00000000000003fb R09: 0000000000000007
Nov 27 11:30:33 localhost kernel: R10: 0000000000000000 R11: ffffffff82ff26ed R12: 0000000000000000
Nov 27 11:30:33 localhost kernel: R13: ffff8fdeea21afd8 R14: ffff8fdee32f8200 R15: 000000000000002a
Nov 27 11:30:33 localhost kernel: FS: 00007fbd9557ff00(0000) GS:ffff8fdeee800000(0000) knlGS:0000000000000000
Nov 27 11:30:33 localhost kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Nov 27 11:30:33 localhost kernel: CR2: 00007fbd95102244 CR3: 000000042556e000 CR4: 0000000000340ef0
Nov 27 11:30:33 localhost kernel: Call Trace:
Nov 27 11:30:33 localhost kernel: __check_heap_object+0xda/0x110
Nov 27 11:30:33 localhost kernel: __check_object_size+0x15d/0x189
Nov 27 11:30:33 localhost kernel: os_memcpy_from_user+0x1b/0x40 [nvidia]
Nov 27 11:30:33 localhost kernel: _nv000936rm+0x7b5/0x900 [nvidia]
Nov 27 11:30:33 localhost kernel: ? rm_ioctl+0x54/0xb0 [nvidia]
Nov 27 11:30:33 localhost kernel: ? nvidia_ioctl+0x60/0x800 [nvidia]
Nov 27 11:30:33 localhost kernel: ? nvidia_ioctl+0x164/0x800 [nvidia]
Nov 27 11:30:33 localhost kernel: ? kmem_cache_free+0x1a7/0x1d0
Nov 27 11:30:33 localhost kernel: ? nvidia_frontend_unlocked_ioctl+0x3a/0x50 [nvidia]
Nov 27 11:30:33 localhost kernel: ? do_vfs_ioctl+0xa4/0x630
Nov 27 11:30:33 localhost kernel: ? ksys_ioctl+0x60/0x90
Nov 27 11:30:33 localhost kernel: ? __x64_sys_ioctl+0x16/0x20
Nov 27 11:30:33 localhost kernel: ? do_syscall_64+0x53/0x110
Nov 27 11:30:33 localhost kernel: ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
Nov 27 11:30:33 localhost kernel: Modules linked in: uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common snd_usb_audio videodev snd_usbmidi_lib snd_rawmidi media hid_saitek snd_seq_device snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi nvidia_drm(POE) drm_kms_helper drm nvidia_modeset(POE) binfmt_misc edac_mce_amd eeepc_wmi asus_wmi sparse_keymap rfkill nls_ascii video nls_cp437 joydev vfat fat kvm_amd efi_pstore kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcc_cpufreq snd_hda_intel wmi_bmof snd_hda_codec snd_hda_core snd_hwdep snd_pcm efivars pcspkr r8125(OE) snd_timer sp5100_tco ccp snd rng_core soundcore evdev acpi_cpufreq nvidia(POE) ipmi_devintf ipmi_msghandler nct6775 hwmon_vid efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 fscrypto ecb hid_cherry
Nov 27 11:30:33 localhost kernel: hid_generic usbhid hid btrfs xor zstd_decompress zstd_compress xxhash raid6_pq libcrc32c crc32c_generic crc32c_intel mxm_wmi ahci xhci_pci libahci xhci_hcd aesni_intel libata aes_x86_64 crypto_simd igb usbcore cryptd glue_helper scsi_mod nvme i2c_piix4 nvme_core dca usb_common i2c_algo_bit wmi button
Nov 27 11:30:33 localhost kernel: ---[ end trace e7cdcad97dd00fdf ]---
Nov 27 11:30:33 localhost kernel: general protection fault: 0000 [#2] SMP NOPTI
Nov 27 11:30:33 localhost kernel: CPU: 2 PID: 875 Comm: Xorg Tainted: P D OE 4.19.0-6-amd64 #1 Debian 4.19.67-2+deb10u2
Nov 27 11:30:33 localhost kernel: RIP: 0010:_nv006972rm+0x2c/0x330 [nvidia]
Nov 27 11:30:33 localhost kernel: Code: 48 85 d2 74 07 48 63 47 08 48 01 d0 48 8b 17 48 85 d2 75 16 e9 9d 02 00 00 0f 1f 44 00 00 48 8b 4a 10 48 85 c9 74 17 48 89 ca <48> 39 32 77 ef 0f 83 29 02 00 00 48 8b 4a 18 48 85 c9 75 e9 48 89
Nov 27 11:30:33 localhost kernel: RSP: 0018:ffffb4e80a0cfd20 EFLAGS: 00010002
Nov 27 11:30:33 localhost kernel: RAX: ffffb4e80a0cfda8 RBX: ffffb4e80a0cfd50 RCX: 000700008040003d
Nov 27 11:30:33 localhost kernel: RDX: 000700008040003d RSI: 000000000000036b RDI: ffffffffc18833d8
Nov 27 11:30:33 localhost kernel: RBP: ffff8fdee57c2ff0 R08: 0000000000000000 R09: ffffb4e80a0cfda4
Nov 27 11:30:33 localhost kernel: R10: 0000000000000000 R11: 0000000000000001 R12: 0000000800000008
Nov 27 11:30:33 localhost kernel: R13: ffff8fdee4759800 R14: ffff8fdee5135800 R15: ffff8fdee4759c58
Nov 27 11:30:33 localhost kernel: FS: 00007fbd9557ff00(0000) GS:ffff8fdeee880000(0000) knlGS:0000000000000000
Nov 27 11:30:33 localhost kernel: CR2: 0000562cb014a4c8 CR3: 0000000426afc000 CR4: 0000000000340ee0
Nov 27 11:30:33 localhost kernel: ? _nv035415rm+0xf1/0x1d0 [nvidia]
Nov 27 11:30:33 localhost kernel: ? rm_free_unused_clients+0x2d/0xa0 [nvidia]
Nov 27 11:30:33 localhost kernel: ? os_pci_read_dword+0x12/0x30 [nvidia]
Nov 27 11:30:33 localhost kernel: ? nvidia_close+0x94/0x3a0 [nvidia]
Nov 27 11:30:33 localhost kernel: ? nvidia_frontend_close+0x2a/0x40 [nvidia]
Nov 27 11:30:33 localhost kernel: ? __fput+0xac/0x1e0
Nov 27 11:30:33 localhost kernel: ? task_work_run+0x8a/0xb0
Nov 27 11:30:33 localhost kernel: ? do_exit+0x2e3/0xb90
Nov 27 11:30:33 localhost kernel: ? rewind_stack_do_exit+0x17/0x20
Nov 27 11:30:33 localhost kernel: ---[ end trace e7cdcad97dd00fe0 ]---
Nov 27 11:30:33 localhost kernel: audit: type=1400 audit(1574850633.415:35): apparmor="ALLOWED" operation="open" profile="/usr/sbin/sssd" name="/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:05.0/0000:05:00.0/net/enp5s0/type" pid=625 comm="sssd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Nov 27 11:30:33 localhost kernel: Fixing recursive fault but reboot is needed!
Xorg log:
[ 6.276]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 6.276] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[ 6.276] Current Operating System: Linux localhost 4.19.0-6-amd64 #1 SMP Debian 4.19.67-2+deb10u2 (2019-11-11) x86_64
[ 6.276] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-6-amd64 root=UUID=91e89446-e584-4da0-8d3c-6993b3360cfe ro
[ 6.276] Build Date: 05 March 2019 08:11:12PM
[ 6.276] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[ 6.276] Current version of pixman: 0.36.0
[ 6.276] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 6.276] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 6.276] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 27 11:30:31 2019
[ 6.277] (==) Using config file: "/etc/X11/xorg.conf"
[ 6.277] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.278] (==) ServerLayout "Layout0"
[ 6.278] (**) |-->Screen "Screen0" (0)
[ 6.278] (**) | |-->Monitor "Monitor0"
[ 6.278] (**) | |-->Device "Device0"
[ 6.278] (**) |-->Input Device "Keyboard0"
[ 6.278] (**) |-->Input Device "Mouse0"
[ 6.278] (**) Option "Xinerama" "0"
[ 6.278] (==) Automatically adding devices
[ 6.278] (==) Automatically enabling devices
[ 6.278] (==) Automatically adding GPU devices
[ 6.278] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.279] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 6.279] Entry deleted from font path.
[ 6.280] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 6.280] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.280] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 6.280] (WW) Disabling Keyboard0
[ 6.280] (WW) Disabling Mouse0
[ 6.280] (II) Loader magic: 0x5611eec71e20
[ 6.280] (II) Module ABI versions:
[ 6.280] X.Org ANSI C Emulation: 0.4
[ 6.280] X.Org Video Driver: 24.0
[ 6.280] X.Org XInput driver : 24.1
[ 6.280] X.Org Server Extension : 10.0
[ 6.280] (++) using VT number 7
[ 6.280] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.280] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.280] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 6.283] (--) PCI:*(9@0:0:0) 10de:1cb3:10de:11be rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[ 6.283] (--) PCI: (10@0:0:0) 10de:1cb3:10de:11be rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 6.283] (II) LoadModule: "glx"
[ 6.285] (WW) Warning, couldn't open module glx
[ 6.285] (EE) Failed to load module "glx" (module does not exist, 0)
[ 6.285] (II) LoadModule: "nvidia"
[ 6.285] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 6.289] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 6.289] compiled for 4.0.2, module version = 1.0.0
[ 6.289] Module class: X.Org Video Driver
[ 6.290] (II) NVIDIA dlloader X Driver 418.74 Wed May 1 11:26:02 CDT 2019
[ 6.290] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 6.292] (II) Loading sub module "fb"
[ 6.292] (II) LoadModule: "fb"
[ 6.292] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 6.292] (II) Module fb: vendor="X.Org Foundation"
[ 6.292] compiled for 1.20.4, module version = 1.0.0
[ 6.292] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.292] (II) Loading sub module "wfb"
[ 6.292] (II) LoadModule: "wfb"
[ 6.292] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 6.293] (II) Module wfb: vendor="X.Org Foundation"
[ 6.293] compiled for 1.20.4, module version = 1.0.0
[ 6.293] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.293] (II) Loading sub module "ramdac"
[ 6.293] (II) LoadModule: "ramdac"
[ 6.293] (II) Module "ramdac" already built-in
[ 6.294] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 6.294] (==) NVIDIA(0): RGB weight 888
[ 6.294] (==) NVIDIA(0): Default visual is TrueColor
[ 6.294] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.294] (**) NVIDIA(0): Option "Stereo" "0"
[ 6.294] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-3"
[ 6.294] (**) NVIDIA(0): Option "SLI" "off"
[ 6.294] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 6.294] (**) NVIDIA(0): Option "BaseMosaic" "on"
[ 6.294] (**) NVIDIA(0): Stereo disabled by request
[ 6.294] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 6.294] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 6.294] (**) NVIDIA(0): Option "MetaModes" "GPU-7137ccdb-3613-519b-ca6f-26b8ddc492be.DP-3: nvidia-auto-select +0+0, GPU-7137ccdb-3613-519b-ca6f-26b8ddc492be.DP-1: nvidia-auto-select +1920+0, GPU-7137ccdb-3613-519b-ca6f-26b8ddc492be.DP-5: nvidia-auto-select +3840+0, GPU-0470c289-9aa1-64d5-76f3-83e1f1ae718d.DP-1: nvidia-auto-select +5760+0, GPU-0470c289-9aa1-64d5-76f3-83e1f1ae718d.DP-3: nvidia-auto-select +7680+0, GPU-0470c289-9aa1-64d5-76f3-83e1f1ae718d.DP-5: nvidia-auto-select +9600+0"
[ 6.294] (**) NVIDIA(0): Enabling 2D acceleration
[ 6.294] (II) Loading sub module "glxserver_nvidia"
[ 6.294] (II) LoadModule: "glxserver_nvidia"
[ 6.294] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 6.310] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 6.310] compiled for 4.0.2, module version = 1.0.0
[ 6.310] Module class: X.Org Server Extension
[ 6.311] (II) NVIDIA GLX Module 418.74 Wed May 1 11:24:49 CDT 2019
[ 7.609] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[ 7.610] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
nvidia-bug-report.log.gz (2 MB)
