Debian 10, 2 NVS 510 cards, Base Mosaic failure
Fresh install Debian 10 base system. I run apt install nvidia-driver and then sudo nvidia-settings
I have three NVS 510 cards installed in this system, but for this simple test they are arranged as follows:
GPU0: 1 single LG 1920x1080 screen
GPU1: 1 single LG 1920x1080 screen
GPU2: Nothing connected
The only changes i make are the enabling of BaseMosaic and setting the 2nd monitor on the same X screen as the first monitor. I have them side by side.
Applying the settings doesn’t work because it requires a restart of the X server, so I use the nvidia settings application to save the X configuration as /etc/X11/xorg.conf.
Opening a terminal and running service display-manager restart gives me a black screen.
Via SSH, I can log in and see the following in the Xorg.0.log:
[     5.915] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     5.915] (==) NVIDIA(0): RGB weight 888
[     5.915] (==) NVIDIA(0): Default visual is TrueColor
[     5.915] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     5.915] (**) NVIDIA(0): Option "Stereo" "0"
[     5.915] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[     5.915] (**) NVIDIA(0): Option "SLI" "off"
[     5.915] (**) NVIDIA(0): Option "MultiGPU" "Off"
[     5.915] (**) NVIDIA(0): Option "BaseMosaic" "on"
[     5.916] (**) NVIDIA(0): Stereo disabled by request
[     5.916] (**) NVIDIA(0): NVIDIA SLI disabled.
[     5.916] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[     5.916] (**) NVIDIA(0): Option "MetaModes" "GPU-e4bbb1c5-499f-0a22-e113-fa8b260c706d.DP-1: nvidia-auto-select +0+0, GPU-4e0c41bc-2a23-ae2c-d859-e4c5807daf81.DP-1: nvidia-auto-select +0+1080"
[     5.916] (**) NVIDIA(0): Enabling 2D acceleration
[     5.916] (II) Loading sub module "glxserver_nvidia"
[     5.916] (II) LoadModule: "glxserver_nvidia"
[     5.917] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[     6.025] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     6.025]    compiled for 4.0.2, module version = 1.0.0
[     6.025]    Module class: X.Org Server Extension
[     6.026] (II) NVIDIA GLX Module  418.197.02  Thu Mar 18 22:32:24 UTC 2021
[     6.697] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[     6.723] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[     7.437] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[     7.441] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[     7.441] (EE) NVIDIA(0): Failing initialization of X screen 0
[     7.441] (II) UnloadModule: "nvidia"
[     7.441] (II) UnloadSubModule: "glxserver_nvidia"
[     7.441] (II) Unloading glxserver_nvidia
[     7.441] (II) UnloadSubModule: "wfb"
[     7.441] (II) UnloadSubModule: "fb"
[     7.441] (EE) Screen(s) found, but none have a usable configuration.
[     7.441] (EE)
Fatal server error:
[     7.442] (EE) no screens found(EE)
[     7.442] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[     7.442] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     7.442] (EE)
[     7.445] (EE) Server terminated with error (1). Closing log file.
Any idea why this fails so completely?
And why are you on such an ancient driver branch? The latest (and last) driver branch that works on that is the 470 series.
Couple reasons:
Based on Debian’s documentation NvidiaGraphicsDrivers the newest version from buster-backports is 460.73.01, which is where I started. That gave me an SLI error detailed in this ticket:
Based on the advice there I backed off to 418 as per the Debian documentation.
I can certainly try the 470 branch, it’s not in the Debian repo but that should be trivial to install. Lemme report back.
Enabling BaseMosaic as per the first post, same result (no X output at all). Going to the 470 drivers gives me the SLI error I was getting from the other thread.
[   147.765] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[   147.766] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[   147.766] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[   147.766] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:2:0:0 is part of an active SLI
[   147.766] (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
[   147.766] (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
[   147.766] (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
[   147.766] (EE) NVIDIA(GPU-0):     information.
[   147.766] (EE)  *** Aborting ***
[   147.766] (EE) NVIDIA(0): Failing initialization of X screen
[   147.766] (II) UnloadModule: "nvidia"
[   147.766] (II) UnloadSubModule: "glxserver_nvidia"
[   147.766] (II) Unloading glxserver_nvidia
[   147.766] (II) UnloadSubModule: "wfb"
[   147.766] (II) UnloadSubModule: "fb"
[   147.766] (**) NVIDIA(G0): Depth 24, (--) framebuffer bpp 32
[   147.766] (==) NVIDIA(G0): RGB weight 888
[   147.766] (==) NVIDIA(G0): Default visual is TrueColor
[   147.766] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[   147.766] (**) NVIDIA(G0): Option "Stereo" "0"
[   147.766] (**) NVIDIA(G0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[   147.766] (**) NVIDIA(G0): Option "SLI" "off"
[   147.766] (**) NVIDIA(G0): Option "MultiGPU" "Off"
[   147.766] (**) NVIDIA(G0): Option "BaseMosaic" "on"
[   147.767] (**) NVIDIA(G0): Stereo disabled by request
[   147.767] (**) NVIDIA(G0): NVIDIA SLI disabled.
[   147.767] (**) NVIDIA(G0): NVIDIA Multi-GPU disabled.
[   147.767] (WW) NVIDIA(G0): Base Mosaic is available only on screen 0.  Disabling Base
[   147.767] (WW) NVIDIA(G0):     Mosaic.
[   147.767] (EE) NVIDIA(G0): Only one X screen is supported when Base Mosaic is enabled.
[   147.767] (EE) NVIDIA(G0):     Disabling this screen.
[   147.767] (EE) NVIDIA(G0): Failing initialization of X screen
[   147.767] (II) NVIDIA(G1):  (GPU-2) already has an X screen assigned; skipping this GPU
[   147.767] (II) NVIDIA(G1):     screen
[   147.767] (EE) NVIDIA(G1): Failing initialization of X screen
[   147.767] (II) UnloadModule: "nvidia"
[   147.767] (II) UnloadSubModule: "wfb"
[   147.767] (II) UnloadSubModule: "fb"
[   147.767] (EE) Screen(s) found, but none have a usable configuration.
[   147.767] (EE)
Fatal server error:
[   147.767] (EE) no screens found(EE)
[   147.767] (EE)
nvidia-bug-report.log.gz (2.3 MB)
A good but frustrating update, the Xorg log in the last update shows the text The NVIDIA graphics device PCI:2:0:0 is part of an active SLI configuration.
Literally at a loss of what to change I went in and arbitrarily set the Device to point at BusID 1:0:0 instead of 2:0:0
The resulting Xorg log complained that 2:0:0 is actually the main device and should be specified in xorg.conf
So all I did was change it back to 2:0:0
Now I have perfectly working BaseMosaic in Debian; two connected physical displays, connected on 2 different NVS 510 video cards, merged into the same X window and working as expected. I wish I knew what actually fixed things, but there you have it.
My next step is to get to a full 9 monitor configuration across 3 cards and I believe I should be able to do this simply by adding additional metamode values in the Xorg.conf.
Thanks for all who helped, sorry my answer is a mystery to me.
