I tried to use two NVIDIA cards for lot monitors, but I got error.
Cards are Quadro2000 and GeForce GTX750Ti. Use nvidia driver on Linux 4.6.2-1 x86_64.
Distribution is Manjaro Linux stable latest.
I was going to use Base Mosaic, but I understood they don’t support NVIDIA Mosaic.
I use Xinerama with three screens now. It’s very unstable but work.
But I got same error when enabled Base Mosaic or MultiGPU.
[ 24.048] (EE) NVIDIA(GPU-0): GPUs:
[ 24.048] (EE) NVIDIA(GPU-0): 1) NVIDIA GPU at PCI:15:0:0
[ 24.048] (EE) NVIDIA(GPU-0): 2) NVIDIA GPU at PCI:40:0:0
[ 24.048] (EE) NVIDIA(GPU-0): Errors:
[ 24.048] (EE) NVIDIA(GPU-0): - GPU PCI IDs do not match
This is log when simply enabled MultiGPU.
[ 21.864]
X.Org X Server 1.17.4
Release Date: 2015-10-28
[ 21.864] X Protocol Version 11, Revision 0
[ 21.864] Build Operating System: Linux 4.2.5-1-ARCH x86_64
[ 21.864] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
[ 21.864] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
[ 21.864] Build Date: 01 November 2015 10:36:50AM
[ 21.864]
[ 21.864] Current version of pixman: 0.34.0
[ 21.864] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 21.864] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 21.864] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul 18 20:17:09 2016
[ 21.868] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 21.868] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21.871] (==) ServerLayout "Layout0"
[ 21.871] (**) |-->Screen "Screen0" (0)
[ 21.871] (**) | |-->Monitor "Monitor0"
[ 21.874] (**) | |-->Device "Device0"
[ 21.874] (**) |-->Input Device "Keyboard0"
[ 21.874] (**) |-->Input Device "Mouse0"
[ 21.874] (==) Automatically adding devices
[ 21.874] (==) Automatically enabling devices
[ 21.874] (==) Automatically adding GPU devices
[ 21.876] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 21.876] Entry deleted from font path.
[ 21.876] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 21.876] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 21.876] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 21.876] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/OTF/,
/usr/share/fonts/Type1/
[ 21.876] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 21.876] (**) Extension "Composite" is enabled
[ 21.876] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 21.876] (WW) Disabling Keyboard0
[ 21.876] (WW) Disabling Mouse0
[ 21.877] (II) Loader magic: 0x817d60
[ 21.877] (II) Module ABI versions:
[ 21.877] X.Org ANSI C Emulation: 0.4
[ 21.877] X.Org Video Driver: 19.0
[ 21.877] X.Org XInput driver : 21.1
[ 21.877] X.Org Server Extension : 9.0
[ 21.878] (EE) systemd-logind: failed to get session: PID 965 does not belong to any known session
[ 21.880] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[ 21.880] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 21.880] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 21.881] (II) LoadModule: "glx"
[ 21.889] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 22.048] (II) Module glx: vendor="NVIDIA Corporation"
[ 22.048] compiled for 4.0.2, module version = 1.0.0
[ 22.048] Module class: X.Org Server Extension
[ 22.050] (II) NVIDIA GLX Module 364.19 Tue Apr 19 14:10:52 PDT 2016
[ 22.052] (II) LoadModule: "nvidia"
[ 22.052] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 22.070] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 22.070] compiled for 4.0.2, module version = 1.0.0
[ 22.070] Module class: X.Org Video Driver
[ 22.072] (II) NVIDIA dlloader X Driver 364.19 Tue Apr 19 13:48:55 PDT 2016
[ 22.072] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 22.073] (++) using VT number 7
[ 22.277] (II) Loading sub module "fb"
[ 22.277] (II) LoadModule: "fb"
[ 22.279] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 22.283] (II) Module fb: vendor="X.Org Foundation"
[ 22.283] compiled for 1.17.4, module version = 1.0.0
[ 22.283] ABI class: X.Org ANSI C Emulation, version 0.4
[ 22.283] (II) Loading sub module "wfb"
[ 22.283] (II) LoadModule: "wfb"
[ 22.283] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 22.288] (II) Module wfb: vendor="X.Org Foundation"
[ 22.288] compiled for 1.17.4, module version = 1.0.0
[ 22.288] ABI class: X.Org ANSI C Emulation, version 0.4
[ 22.288] (II) Loading sub module "ramdac"
[ 22.288] (II) LoadModule: "ramdac"
[ 22.288] (II) Module "ramdac" already built-in
[ 22.295] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 22.295] (==) NVIDIA(0): RGB weight 888
[ 22.295] (==) NVIDIA(0): Default visual is TrueColor
[ 22.295] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 22.297] (**) NVIDIA(0): Option "NoLogo" "1"
[ 22.297] (**) NVIDIA(0): Option "MultiGPU" "on"
[ 22.297] (**) NVIDIA(0): NVIDIA Multi-GPU auto-select rendering option.
[ 22.298] (**) NVIDIA(0): Enabling 2D acceleration
[ 24.048] (EE) NVIDIA(GPU-0): Failed to find a valid Multi-GPU configuration.
[ 24.048] (EE) NVIDIA(GPU-0): Invalid Multi-GPU configuration 1 of 1:
[ 24.048] (WW) NVIDIA(GPU-0): Failed to find a valid Multi-GPU configuration for the NVIDIA
[ 24.048] (WW) NVIDIA(GPU-0): graphics device PCI:15:0:0. Please see Chapter 28:
[ 24.048] (WW) NVIDIA(GPU-0): Configuring SLI and Multi-GPU FrameRendering in the README
[ 24.048] (WW) NVIDIA(GPU-0): for troubleshooting suggestions.
and one when enabled Base Mosaic with nvidia-settings.
[ 20.386]
[ 20.386] X Protocol Version 11, Revision 0
[ 20.386] Build Operating System: Linux 4.2.5-1-ARCH x86_64
[ 20.386] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
[ 20.386] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
[ 20.386] Build Date: 01 November 2015 10:36:50AM
[ 20.386]
[ 20.386] Current version of pixman: 0.34.0
[ 20.386] Before reporting problems, check http://wiki.x.org
[ 20.386] Markers: (--) probed, (**) from config file, (==) default setting,
[ 20.386] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 16 12:02:14 2016
[ 20.390] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 20.390] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 20.393] (==) ServerLayout "Layout0"
[ 20.393] (**) |-->Screen "Screen0" (0)
[ 20.393] (**) | |-->Monitor "Monitor0"
[ 20.396] (**) | |-->Device "Device0"
[ 20.396] (**) |-->Input Device "Keyboard0"
[ 20.396] (**) |-->Input Device "Mouse0"
[ 20.396] (**) Option "Xinerama" "0"
[ 20.396] (==) Automatically adding devices
[ 20.396] (==) Automatically enabling devices
[ 20.396] (==) Automatically adding GPU devices
[ 20.401] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 20.401] Entry deleted from font path.
[ 20.401] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 20.402] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 20.402] Entry deleted from font path.
[ 20.402] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 20.402] (==) FontPath set to:
[ 20.402] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 20.402] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 20.402] (WW) Disabling Keyboard0
[ 20.402] (WW) Disabling Mouse0
[ 20.402] (II) Loader magic: 0x817d60
[ 20.402] (II) Module ABI versions:
[ 20.402] X.Org ANSI C Emulation: 0.4
[ 20.402] X.Org Video Driver: 19.0
[ 20.402] X.Org XInput driver : 21.1
[ 20.402] X.Org Server Extension : 9.0
[ 20.403] (EE) systemd-logind: failed to get session: PID 851 does not belong to any known session
[ 20.405] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[ 20.405] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 20.405] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 20.406] (II) LoadModule: "glx"
[ 20.413] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 20.557] (II) Module glx: vendor="NVIDIA Corporation"
[ 20.557] compiled for 4.0.2, module version = 1.0.0
[ 20.557] Module class: X.Org Server Extension
[ 20.559] (II) NVIDIA GLX Module 364.19 Tue Apr 19 14:10:52 PDT 2016
[ 20.570] (II) LoadModule: "nvidia"
[ 20.571] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 20.588] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 20.588] compiled for 4.0.2, module version = 1.0.0
[ 20.588] Module class: X.Org Video Driver
[ 20.590] (II) NVIDIA dlloader X Driver 364.19 Tue Apr 19 13:48:55 PDT 2016
[ 20.590] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 20.591] (++) using VT number 7
[ 20.795] (II) Loading sub module "fb"
[ 20.795] (II) LoadModule: "fb"
[ 20.797] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 20.800] (II) Module fb: vendor="X.Org Foundation"
[ 20.800] compiled for 1.17.4, module version = 1.0.0
[ 20.800] ABI class: X.Org ANSI C Emulation, version 0.4
[ 20.800] (II) Loading sub module "wfb"
[ 20.800] (II) LoadModule: "wfb"
[ 20.801] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 20.805] (II) Module wfb: vendor="X.Org Foundation"
[ 20.805] compiled for 1.17.4, module version = 1.0.0
[ 20.805] ABI class: X.Org ANSI C Emulation, version 0.4
[ 20.805] (II) Loading sub module "ramdac"
[ 20.805] (II) LoadModule: "ramdac"
[ 20.805] (II) Module "ramdac" already built-in
[ 20.812] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 20.812] (==) NVIDIA(0): RGB weight 888
[ 20.812] (==) NVIDIA(0): Default visual is TrueColor
[ 20.812] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 20.814] (**) NVIDIA(0): Option "Stereo" "0"
[ 20.814] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[ 20.814] (**) NVIDIA(0): Option "SLI" "off"
[ 20.814] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 20.814] (**) NVIDIA(0): Option "BaseMosaic" "on"
[ 20.814] (**) NVIDIA(0): Stereo disabled by request
[ 20.815] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 20.815] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 20.815] (**) NVIDIA(0): Option "MetaModes" "GPU-e85b6d81-cd8a-863c-9de4-f02b26aefc6e.DVI-I-1: nvidia-auto-select +0+0, GPU-e85b6d81-cd8a-863c-9de4-f02b26aefc6e.DP-0: nvidia-auto-select +1920+0, GPU-a26d8e50-e07f-4980-899e-201371772a1d.HDMI-0: nvidia-auto-select +3840+0"
[ 20.815] (**) NVIDIA(0): Enabling 2D acceleration
[ 22.573] (EE) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration.
[ 22.573] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 1 of 1:
[ 22.573] (EE) NVIDIA(GPU-0): GPUs:
[ 22.573] (EE) NVIDIA(GPU-0): 1) NVIDIA GPU at PCI:15:0:0
[ 22.573] (EE) NVIDIA(GPU-0): 2) NVIDIA GPU at PCI:40:0:0
[ 22.573] (EE) NVIDIA(GPU-0): Errors:
[ 22.573] (EE) NVIDIA(GPU-0): - GPU PCI IDs do not match
[ 22.573] (WW) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration for the
[ 22.573] (WW) NVIDIA(GPU-0): NVIDIA graphics device PCI:15:0:0. Please see Chapter 28:
[ 22.573] (WW) NVIDIA(GPU-0): Configuring SLI and Multi-GPU FrameRendering in the README
[ 22.573] (WW) NVIDIA(GPU-0): for troubleshooting suggestions.
Logs says
but lspci says different thing.
$ lspci | grep VGA
0f:00.0 VGA compatible controller: NVIDIA Corporation GF106GL [Quadro 2000] (rev a1)
28:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a2)
If write 0f:00:0 or 28:00:0 to BusID, didn’t start X.
[ 56.257]
[ 56.257] X Protocol Version 11, Revision 0
[ 56.257] Build Operating System: Linux 4.2.5-1-ARCH x86_64
[ 56.257] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
[ 56.257] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
[ 56.257] Build Date: 01 November 2015 10:36:50AM
[ 56.257]
[ 56.257] Current version of pixman: 0.34.0
[ 56.257] Before reporting problems, check http://wiki.x.org
[ 56.257] Markers: (--) probed, (**) from config file, (==) default setting,
[ 56.258] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 16 12:06:17 2016
[ 56.258] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 56.258] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 56.258] (==) ServerLayout "Layout0"
[ 56.258] (**) |-->Screen "Screen0" (0)
[ 56.258] (**) | |-->Monitor "Monitor0"
[ 56.258] (**) | |-->Device "Device0"
[ 56.258] (**) |-->Input Device "Keyboard0"
[ 56.258] (**) |-->Input Device "Mouse0"
[ 56.258] (**) Option "Xinerama" "0"
[ 56.258] (==) Automatically adding devices
[ 56.258] (==) Automatically enabling devices
[ 56.258] (==) Automatically adding GPU devices
[ 56.258] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 56.258] Entry deleted from font path.
[ 56.258] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 56.258] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 56.258] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 56.258] (==) FontPath set to:
[ 56.258] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 56.258] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 56.258] (WW) Disabling Keyboard0
[ 56.258] (WW) Disabling Mouse0
[ 56.258] (II) Loader magic: 0x817d60
[ 56.258] (II) Module ABI versions:
[ 56.258] X.Org ANSI C Emulation: 0.4
[ 56.258] X.Org Video Driver: 19.0
[ 56.258] X.Org XInput driver : 21.1
[ 56.258] X.Org Server Extension : 9.0
[ 56.260] (EE) systemd-logind: failed to get session: PID 1001 does not belong to any known session
[ 56.262] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[ 56.262] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 56.262] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 56.262] (II) LoadModule: "glx"
[ 56.263] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 56.267] (II) Module glx: vendor="NVIDIA Corporation"
[ 56.267] compiled for 4.0.2, module version = 1.0.0
[ 56.267] Module class: X.Org Server Extension
[ 56.267] (II) NVIDIA GLX Module 364.19 Tue Apr 19 14:10:52 PDT 2016
[ 56.267] (II) LoadModule: "nvidia"
[ 56.267] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 56.268] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 56.268] compiled for 4.0.2, module version = 1.0.0
[ 56.268] Module class: X.Org Video Driver
[ 56.268] (II) NVIDIA dlloader X Driver 364.19 Tue Apr 19 13:48:55 PDT 2016
[ 56.268] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 56.268] (++) using VT number 7
[ 56.268] (EE) No devices detected.
[ 56.268] (EE)
Fatal server error:
[ 56.268] (EE) no screens found(EE)
[ 56.268] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 56.268] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 56.268] (EE)
What’s wrong and how to fix it?
Thanks in advance.
