Hello.
My setup is a jetson nano module connected to 8 cameras through a usb hub and 1 camera via csi. The usb cameras provide solo frames of specific instants, while the other one capture short videos between five and fifteen seconds.
I’ve been struggling with a problem regarding data acquisition. Sometimes, during the acquisition of video from imx-219, nvargus-daemon logs the following problems:
Jun 07 11:58:28 nvargus-daemon[82551]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== python3[82538]: Connection established (7F8F335130)OFParse
rListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jun 07 11:58:28 nvargus-daemon[82551]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Jun 07 11:58:28 nvargus-daemon[82551]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jun 07 11:58:28 nvargus-daemon[82551]: ---- imager: No override file found. ----
Jun 07 11:58:28 nvargus-daemon[82551]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp,
function findDevice(), line 256)
Jun 07 11:58:28 nvargus-daemon[82551]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function i
nitialize(), line 60)
Jun 07 11:58:28 nvargus-daemon[82551]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi
.cpp, function initialize(), line 106)
Jun 07 11:58:28 nvargus-daemon[82551]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Jun 07 11:58:28 nvargus-daemon[82551]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Jun 07 11:58:28 nvargus-daemon[82551]: NvPclStartPlatformDrivers: Failed to start module drivers
Jun 07 11:58:28 nvargus-daemon[82551]: NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
Jun 07 11:58:28 nvargus-daemon[82551]: NvPclOpen: PCL Open Failed. Error: 0xf
Jun 07 11:58:28 nvargus-daemon[82551]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(
), line 582)
Jun 07 11:58:28 nvargus-daemon[82551]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Jun 07 11:58:28 nvargus-daemon[82551]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 295)
Jun 07 11:58:28 nvargus-daemon[82551]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 458)
Jun 07 11:58:28 nvargus-daemon[82551]: Acquiring SCF Camera device source via index 0 has failed. ---- imager: No override file found. ----
Jun 07 11:58:28 nvargus-daemon[82551]: LSC: LSC surface is not based on full res!
Jun 07 11:58:28 nvargus-daemon[82551]: initializeDevNode: Failed to open dev node '/dev/camera/video5'; No such file or directory, trying alternate default location
Jun 07 11:58:28 nvargus-daemon[82551]: (NvCamV4l2) Error BadParameter: Control 10094858 not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, fu
nction findControlById(), line 1874)
Jun 07 11:58:28 nvargus-daemon[82551]: (NvCamV4l2) Error BadParameter: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getCo
ntrolRange(), line 331)
Jun 07 11:58:28 nvargus-daemon[82551]: initialize: focus query failed
Jun 07 11:58:28 nvargus-daemon[82551]: initializeDevNode: Failed to open dev node '/dev/camera/video7'; No such file or directory, trying alternate default location
Jun 07 11:58:28 nvargus-daemon[82551]: initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
Jun 07 11:58:28 nvargus-daemon[82551]: initializeDevNode: Failed to open dev node '/dev/camera/video3'; No such file or directory, trying alternate default location
Jun 07 11:58:28 nvargus-daemon[82551]: initializeDevNode: Failed to open dev node '/dev/camera/video2'; No such file or directory, trying alternate default location
Jun 07 11:58:28 nvargus-daemon[82551]: initializeDevNode: Failed to open dev node '/dev/camera/video4'; No such file or directory, trying alternate default location
I have already tried the fixes suggested in this question, however, no success.
kernel version: 4.9.140-l4t-r32.4+ga28ca7b3779d;
