Hi, I am importing the URDF of a dexterous hand but I cannot actuate all the joints. Each finger has 3 joints (proximal, middle and distal), but for some reason I can actuate only the middle one. The URDF seems to be imported fine.
When I set the PD target of the proximal joint nothing happens:
Hi, I have the same issue, only some of the joints are actuated, the URDF looks fine with correct limits and inertial properties. Have you figured out what the problem is? @gstate
Here is a side by side comparison of the pinky proximal joint on the left which works, and the pinky middle joint on the right which doesn’t work:
As you can see in the simulation when applying 1 radian drive to each joint, only the proximal joints are actuated while the other joints remain in original position
I managed to overcome the problem in the new preview release by setting the armature property of each joint to 0.0001. I think the problem was that the values of the inertia matrix was very small.
