Problem with tensorboard in tensorflow 2
Good morning, when I try to launch the Tensorboard visualization in my Jupiter notebook -after some callbacks with Tensorboard- using the commands
%load_ext tensorboard
%tensorboard --logdir=./mylogs --port=6006
I get the following error:
ERROR: Failed to launch TensorBoard (exited with 1).
Contents of stderr:
2020-07-24 17:58:23.492332: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libnvinfer.so.6
2020-07-24 17:58:23.492744: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘libnvinfer_plugin.so.6’; dlerror: libnvrtc.so.10.2: cannot open shared object file: No such file or directory
2020-07-24 17:58:23.492765: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:30] Cannot dlopen some TensorRT libraries. If you would like to use Nvidia GPU with TensorRT, please make sure the missing libraries mentioned above are installed properly.
File “/usr/local/bin/tensorboard”, line 8, in
sys.exit(run_main())
File “/usr/local/lib/python3.6/dist-packages/tensorboard/main.py”, line 59, in run_main
default.get_plugins() + default.get_dynamic_plugins(),
File “/usr/local/lib/python3.6/dist-packages/tensorboard/default.py”, line 115, in get_dynamic_plugins
for entry_point in pkg_resources.iter_entry_points(‘tensorboard_plugins’)
File “/usr/lib/python3/dist-packages/pkg_resources/init.py”, line 2323, in load
self.require(*args, **kwargs)
File “/usr/lib/python3/dist-packages/pkg_resources/init.py”, line 2346, in require
items = working_set.resolve(reqs, env, installer, extras=self.extras)
File “/usr/lib/python3/dist-packages/pkg_resources/init.py”, line 783, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.VersionConflict: (setuptools 39.0.1 (/usr/lib/python3/dist-packages), Requirement.parse(‘setuptools>=41.0.0’))
I’m using Tensorflow 2.1 with GPU. If any other detail is needed I’ll provide as soon as I can. If this is not the correct forum section I’d like to ask to move the topic in the correct one.
Thank you all for your kind time and patience.
