The following is installed on a Jetson Xavier NX:
- JetPack 4.6-b199
- CUDA 10.2
- CUDNN 8.2.1
- Tensorflow 2.4.0
- TensorRT 8.0.1.6
Running Tensorflow code results in the following error:
2022-01-09 19:56:27.887280: W tensorflow/stream_executor/platform/default/dso_loader.cc:60] Could not load dynamic library 'libnvinfer.so.7'; dlerror: libnvinfer.so.7: cannot open shared object file: No such file or directory
2022-01-09 19:56:27.887423: F tensorflow/compiler/tf2tensorrt/stub/nvinfer_stub.cc:49] getInferLibVersion symbol not found.
Aborted (core dumped)
There is /usr/lib/aarch64-linux-gpu/libnvinfer.so.8 but no libnvinfer.so.7 in the system.
How do I know which components are causing the incompatibilities and how do I fix them? Appreciate more specifics than “upgrade your installs” because I have 1) tried searching the forums for relevant posts, 2) tried upgrading components and libraries, all to no avail.
