Im having trouble trying to use the Raspberry Pi V2 Camera with my Nano. I have connected the ribbon cable to the Nano but when I try to run the test for the camera feed:
$ gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
… I get the following error:
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:532 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.184149691
Does anyone have any ideas on why this could occur? From what I understand the camera should be able to plug and play with the above command. Are loose connections common?
