Jetson • DeepStream Version
6.2 • JetPack Version (valid for Jetson only)
JetPack 5.1 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs)
questions & possible bug? • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
We’re trying to extend an RTSP Source bin implementation to support JPEG encoding. Our solution, based on the original topic posted here, seems to work well for dGPU but fails on Jetson.
We’ve been able to reproduce the failure with the following gst-launch command.
After various tests, it works when I put the mjpeg =1 option in nvv4l2decoder, but the dgpu and nvv4l2decoder have the same version, but the configuration is slightly different.
