Problems with follow up OTA update after JP5->JP6 OTA update
Hi reagrding the closed topic Problems with follow up OTA update after JP5->JP6 OTA update
I was away and missed your response. The problem still persists.
Below is copied from old topic:
We have the following case:
The devices at the customer have:
  • a custom carrier board
  • a custom kernel
  • are flashed with 35.5.0
  • we used ROOTFS_AB=1
We updated the devices to 36.4.0 with an OTA update containing a new bootloader and rootfs. That works fine.
However if we make a new update OTA from (also containing bootloader since we have to update the second bootchain) the update fails and we go back to the previous bootslot or are left with a bricked device.
On the other hand if we flash JP6 directly to a board we can update it. so it seems to be related to the bootloader updat failing.
  • R35-to-R36 ota update command: sudo -E BASE_BSP=download/R35_5_base_bsp_dir ROOTFS_AB=1 build/Linux_for_Tegra/tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 25GiB jetson-orin-nano-devkit R35-5
    • JP5 to JP6 ota command for reference
  • R36-to-R36 ota update command (rootfs and bootloader): sudo -E BASE_BSP=build/Linux_for_Tegra ROOTFS_AB=1 build/Linux_for_Tegra/tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 25GiB jetson-orin-nano-devkit R36-4
    • Building JP6->JP6 update with bootloader and rootfs
    • This update updates the bootloader after reboot
    • After updating the bootloader it attempts and failes multiple times to boot into the new bootslot
    • Returns to previous bootslot after
    • JTAG_bootloader_rootfs_log.txt (308.8 KB)
  • R36-to-R36 ota update command (bootloader only): sudo -E BASE_BSP=build/Linux_for_Tegra ROOTFS_AB=1 build/Linux_for_Tegra/tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 25GiB -b jetson-orin-nano-devkit R36-4
    • Building JP6->JP6 update with bootloader only
    • After updating the bootloader it hangs while trying to boot (I waited for 12 hours)
    • Is in a unbootable state after
    • JTAG_bootloader_only_log.txt (77.3 KB)
Do you mean update OTA from 35.5.0 will fail, but update from r36.x (r36.3.0) will succeed?
Difference is what was flashed initially.
Initial flash with 35.5.0 → update from 35.5.0 to 36.3.0 → update from 36.3.0 to 36.x fails.
Initial flash with 36.3.0 → update from 36.3.0 to 36.x works.
So at the moment we could update customer devices to JP6 but then any follow up updates wouldnt work.
Thank you for your clarify.
Do you confirm this issue also happened on our dev kit ?
