Problems with follow up OTA update after JP5->JP6 OTA update
We have the following case:
The devices at the customer have:
  • a custom carrier board
  • a custom kernel
  • are flashed with 35.5.0
  • we used ROOTFS_AB=1
We updated the devices to 36.4.0 with an OTA update containing a new bootloader and rootfs. That works fine.
However if we make a new update OTA from (also containing bootloader since we have to update the second bootchain) the update fails and we go back to the previous bootslot or are left with a bricked device.
On the other hand if we flash JP6 directly to a board we can update it. so it seems to be related to the bootloader updat failing.
Do you guys had similiar problems and found a solution?
Could you provide the commands in detail for us to review?
Also do you have the dev kit board to cross check whether the issue exist.
  • R35-to-R36 ota update command: sudo -E BASE_BSP=download/R35_5_base_bsp_dir ROOTFS_AB=1 build/Linux_for_Tegra/tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 25GiB jetson-orin-nano-devkit R35-5
    • JP5 to JP6 ota command for reference
  • R36-to-R36 ota update command (rootfs and bootloader): sudo -E BASE_BSP=build/Linux_for_Tegra ROOTFS_AB=1 build/Linux_for_Tegra/tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 25GiB jetson-orin-nano-devkit R36-4
    • Building JP6->JP6 update with bootloader and rootfs
    • This update updates the bootloader after reboot
    • After updating the bootloader it attempts and failes multiple times to boot into the new bootslot
    • Returns to previous bootslot after
    • JTAG log
  • R36-to-R36 ota update command (bootloader only): sudo -E BASE_BSP=build/Linux_for_Tegra ROOTFS_AB=1 build/Linux_for_Tegra/tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 25GiB -b jetson-orin-nano-devkit R36-4
    • Building JP6->JP6 update with bootloader only
    • After updating the bootloader it hangs while trying to boot (I waited for 12 hours)
    • Is in a unbootable state after
    • JTAG log
~0604
Sorry for the late reponse.
We cannot get your log, please upload log directly on forum topics.
