I am having problems with UDP multicast streams on Xavier. For some reason, Xavier does not see the UDP streams from the first shot. If I run gst-discoverer-1.0, first time it does not detect the stream, but if I run it once more, it detects it. Afterwards, Xavier sees that stream all the time.
nvidia@jetson-0423418009834:~$ gst-discoverer-1.0 udp://239.1.1.1:1111
Analyzing udp://239.1.1.1:1111
Done discovering udp://239.1.1.1:1111
Analyzing URI timed out
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 1920x1088 (x 9), ThumbnailMode = 0
Over-riding video dimension with display dimensionOPENMAX: HandleNewStreamFormat: 3528: Send OMX_EventPortSettingsChanged: nFrameWidth = 1920, nFrameHeight = 1080
NVMEDIA: cbDisplayPicture: 1738: Retunred NULL Frame Buffer
Missing plugins
Topology:
container: MPEG-2 Transport Stream
audio: MPEG-2 AAC
audio: MPEG-4 AAC
video: H.264 (Main Profile)
unknown: meta/x-klv
Properties:
Duration: 99:99:99.999999999
Seekable: no
Live: yes
Tags:
audio codec: MPEG-2 AAC
minimum bitrate: 64500
maximum bitrate: 64500
bitrate: 64537
video codec: H.264
If I try udp://239.2.2.2:2222, same thing will happen, since this is a new stream for Xavier. Same thing happens with ffprobe and with my GStreamer pipeline that works with UDP multicast streams. I have no similar problems on other devices (one of them is Jetson TX2) on my local network.
This happens for all streams (different addresses, streaming different videos) that I tried.
When this happens, netstat -g shows that Xavier did join to the multicast group, but watch netstat -sanu shows that almost no UDP packets are reaching to the Xavier??
Here is my ifconfig output:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.200.223 netmask 255.255.255.0 broadcast 192.168.200.255
inet6 fe80::1543:f2b2:c303:c519 prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:cb:a0:23 txqueuelen 1000 (Ethernet)
RX packets 9215484 bytes 11289201138 (11.2 GB)
RX errors 0 dropped 36 overruns 0 frame 0
TX packets 752456 bytes 510674275 (510.6 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 40
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 3991 bytes 412584 (412.5 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 3991 bytes 412584 (412.5 KB)
