I’ve installed whole SW again both DAX and x86 host.
Not even Nsight makes error this time, with similar warnings, Profiler does not work until now.
I can see some work-process on the console, after building, profiler tries to analyze CUDA application.
But it is terminated just after launch.
Project building and running some examples on the remote DAX work pretty well
Debugging as well.
Should I update CUDA toolkit of Linux Host from 10.0 to 10.1 for newer Nsight?
Dear ddpx2,
I can see the errors are reported as semantic errors in profiler_error.png(Attached picture). So building project should not be problem right?
I had tested nsight with a simple vector addition kernel. I do not see any issue with profiling.
Do you see any error or terminal? If possible please provide a sample to replicate the same on my machine.
