• Hardware Platform (Jetson / GPU) dGPU RTX3070Ti
• DeepStream Version 7.0
• TensorRT Version 8.6
• NVIDIA GPU Driver Version (valid for GPU only) 551.76
• Issue Type( questions, new requirements, bugs) bug
I have install pyds using this deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub. Everything was installed correctly but when I ran my python script with pyds imported and the code Aborted :
[NvMultiObjectTracker] Initialized
0:00:06.946069762 2753 0x561cd82e2ae0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<pgie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:07.148942272 2753 0x561cd82e2ae0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<pgie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine
0:00:07.160023728 2753 0x561cd82e2ae0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<pgie> [UID 1]: Load new model:pgie-config.txt sucessfully
Aborted
When I removed import pyds statement it worked well.
