Hi, I hope I’ve landed in the right category here.
I have been having the problem for some time now that a program crashes as soon as it is started. I have been trying to get the problem under control for weeks now. And no matter which driver I install, nothing helps. I always get the same error in the Windows log.
All cleanups with DDU have not helped. Today I even upgraded from Windows 10 to Windows 11 in the hope that the error would be gone. But no. The error is still there. And I’m really desperate because I can’t mod in my game without this program.
Since the error is related to nVidia, I thought I might ask here and see if this is an Nvidia driver problem?
I hope someone can give me more detailed information about this.
It behaves like this:
I start the editor, and I see the program for a short time. Then it goes out again immediately. Without an error message. The only error message I see is in the Windows log, which I will enter below. There is no error message in the log file of the program itself. The log file loads up to the graphics driver and then stops abruptly. Normally, further modules should be loaded and stored in the log. What does not happen.
Does anyone here have any idea what this could be? Is this error caused by the program or is it an nVidia error?
Translated with DeepL.com (free version)
Windows Log file:
Fehlerhafter Anwendungsname: editor.exe, Version: 10.0.3.0, Zeitstempel: 0x67474b3a
Fehlerhafter Modulname: nvoglv64.dll, Version: 32.0.15.6094, Zeitstempel: 0x66bc35f7
Ausnahmecode: 0xc000041d
Fehleroffset: 0x0000000000ec3772
Fehlerhafte Prozess-ID: 0x2DDC
Fehlerhafte Anwendungsstartzeit: 0x1DB599351CB5CEF
Fehlerhafter Anwendungspfad: C:\Program Files\GIANTS Software\GIANTS_Editor_10.0.3\editor.exe
Fehlerhafter Modulpfad: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_0afec3f2050014a0\nvoglv64.dll
Berichts-ID: 692bfb24-3cde-40a0-b2e8-3761bbb802e8
Vollständiger Name des fehlerhaften Pakets:
Fehlerhafte paketbezogene Anwendungs-ID:
Ereignis-ID: 1000
Editor Log File:
GIANTS Engine Runtime 10.0.0 (37801) 64bit (Build Date: Nov 27 2024)
Copyright (c) 2008-2024, GIANTS Software GmbH (giants-software.com), All Rights Reserved.
Copyright (c) 2003-2024, Christian Ammann and Stefan Geiger, All Rights Reserved.
Application: GIANTS Editor 64bit 10.0.3
PID: 17108
Main System
CPU: AMD Ryzen 7 5700X 8-Core Processor
Virtual Cores: 16
Memory: 16303 MB
OS: Windows NT 11.0 64-bit
[DirectStorage] Configured for base game on a SSD drive
[DirectStorage] No GPU decompression for GDeflate
[DirectStorage] GDeflate Compression Support for ‘FileQueueHigh’ : DSTORAGE_COMPRESSION_SUPPORT_CPU_FALLBACK
[DirectStorage] GDeflate Compression Support for ‘FileQueueNormal’ : DSTORAGE_COMPRESSION_SUPPORT_CPU_FALLBACK
[DirectStorage] GDeflate Compression Support for ‘MemoryQueueRealtime’ : DSTORAGE_COMPRESSION_SUPPORT_CPU_FALLBACK
[DirectStorage] Init success
Physics System
Version: 6.3.7
Thread(s): 2
Audio System
Driver: SoftMixer WASAPI Stereo
Version: 2018.11
Frequency: 48000
Max. active sources: 256
onStart
Render System
Driver: Vulkan
Device: NVIDIA GeForce RTX 2070 SUPER
Vendor ID: 0x10de
Device ID: 0x1e84
Api version: 1.3.289
Driver version: 566.36
Driver version is up to date.
