I am get stuck in the (in)famous login loop after installing nvidia gpu drivers. I have Ubuntu 19.10, intel cpu, and nvidia geforce 1070 gtx (M).
nvidia-bug-report.log.gz (389 KB)
I’m getting this on the driver installation:
nvidia.ko:
Running module version sanity check.
modinfo: ERROR: missing module or filename.
- Original module
- No original module exists within this kernel
nvidia-modeset.ko:
- Original module
- Installation
nvidia-uvm.ko:
- Original module
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
[url]https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/[/url]
Done, thanks!
Now that’s a bit weird, the driver loads fine but this looks like there are two Xservers started at the same time. Did you change anything regarding systemd units recently?
Please do a system update first and check if that resolves the issue.
If not, please check what starts up when you disable the display-manager:
sudo systemctl disable display-manager
After a reboot, you should end up on a text console. Log in, run
sudo systemctl start gdm
The gdm login should come up, does it work then?
You can re-enable the display-manager using
sudo dpkg-reconfigure gdm
No, it´s a fresh installation.
The sudo systemctl disable display-manager doesn’t work.
I still get stuck at the login loop. (i choose to logon without a password on boot)
When i do a sudo systemctl stop gdm at text console ty3 and after a sudo systemctl start gdm, the xserver starts ok showing the keyring password popup, but system freezes.
Really strange.
Weird. Please post the output of
systemctl list-unit-files | grep enabled
snap-core-7917.mount enabled
snap-core18-1223.mount enabled
snap-gnome\x2d3\x2d28\x2d1804-71.mount enabled
snap-gnome\x2dcalculator-501.mount enabled
snap-gnome\x2dcharacters-317.mount enabled
snap-gnome\x2dlogs-81.mount enabled
snap-gtk\x2dcommon\x2dthemes-1353.mount enabled
acpid.path enabled
apport-autoreport.path enabled
cups.path enabled
accounts-daemon.service enabled
anacron.service enabled
apparmor.service enabled
autovt@.service enabled
avahi-daemon.service enabled
bluetooth.service enabled
console-setup.service enabled
cups-browsed.service enabled
cups.service enabled
dbus-fi.w1.wpa_supplicant1.service enabled
dbus-org.bluez.service enabled
dbus-org.freedesktop.Avahi.service enabled
dbus-org.freedesktop.ModemManager1.service enabled
dbus-org.freedesktop.nm-dispatcher.service enabled
dbus-org.freedesktop.resolve1.service enabled
dbus-org.freedesktop.thermald.service enabled
dbus-org.freedesktop.timesync1.service enabled
dmesg.service enabled
e2scrub_reap.service enabled
getty@.service enabled
gpu-manager.service enabled
grub-initrd-fallback.service enabled
irqbalance.service enabled
kerneloops.service enabled
keyboard-setup.service enabled
lm-sensors.service enabled
ModemManager.service enabled
network-manager.service enabled
networkd-dispatcher.service enabled
NetworkManager-dispatcher.service enabled
NetworkManager-wait-online.service enabled
NetworkManager.service enabled
ondemand.service enabled
openvpn.service enabled
pppd-dns.service enabled
rsync.service enabled
rsyslog.service enabled
secureboot-db.service enabled
setvtrgb.service enabled
snapd.autoimport.service enabled
snapd.core-fixup.service enabled
snapd.seeded.service enabled
snapd.service enabled
snapd.system-shutdown.service enabled
switcheroo-control.service enabled
systemd-fsck-root.service enabled-runtime
systemd-remount-fs.service enabled-runtime
systemd-resolved.service enabled
systemd-timesyncd.service enabled
udisks2.service enabled
ufw.service enabled
unattended-upgrades.service enabled
whoopsie.service enabled
wpa_supplicant.service enabled
acpid.socket enabled
apport-forward.socket enabled
avahi-daemon.socket enabled
cups.socket enabled
snapd.socket enabled
uuidd.socket enabled
remote-fs.target enabled
anacron.timer enabled
apt-daily-upgrade.timer enabled
apt-daily.timer enabled
e2scrub_all.timer enabled
fstrim.timer enabled
logrotate.timer enabled
man-db.timer enabled
motd-news.timer enabled
snapd.snap-repair.timer enabled
No idea. I think you should try a reinstall and if that doesn’t work, revert to 19.04 and report to Ubuntu since 19.10 has just been released.
Maybe this is a new gdm bug, you could also just revert to lightdm.
It’s the second time I have reinstall.
Worked! Thank you so much! you’re the man!
I have just reinstalled the gdm3 and worked!
