After I installed driver on ubuntu 18.04, I experienced a problem with nvidia card.
After installing nvidia driver and reboot, I got into login loop and did ctrl+alt+f3 to login.
Then prime-select intel and reboot, I lost my contact to geforce rtx 2070.
When typed nvidia-smi. I got
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
And prime-select nvidia, I can see my graphic cards. But after rebooting, i was in login loop again.
I try to create /etc/X11/xorg.conf and add ‘nogpumanager’ kernel parameter when booting the system and edit in the grub menu. But it does not work for me. I still trapped in the login page.
Attached are the nvidia-bug-report generated from prime-select intel and prime-select nvidia.
To clarify the solution:
sudo prime-select nvidia
find the busid and identifier of the board board controller, which is “PCI:8:0:0” and “ASPEED” for my board
bus info: pci@0000:01:00.0
capabilities: vga_controller bus_master cap_list rom
bus info: pci@0000:02:00.0
bus info: pci@0000:03:00.0
bus info: pci@0000:04:00.0
bus info: pci@0000:05:00.0
bus info: pci@0000:08:00.0
bus info: pci@0000:81:00.0
bus info: pci@0000:82:00.0
bus info: pci@0000:83:00.0
bus info: pci@0000:84:00.0
bus info: pci@0000:85:00.0
b. Find the line starting with GRUB_CMDLINE_LINUX_DEFAULT and append “nogpumanager”.
GRUB_CMDLINE_LINUX_DEFAULT=“nogpumanager quiet splash”
save the file and exit.
c.
sudo update-grub
reboot
This time you should get into the ubuntu interface.
I tried but after typing update initramfs, I got:
update-initramfs: Generating /boot/initrd.img-4.15.0-39-generic
W: possible missing firmware /lib/firmware/ast_dp501_fw.bin for module ast
W: initramfs-tools configuration sets RESUME=UUID=09e25397-4a2c-4fb0-a605-a7013eecb59c
W: but no matching swap device is available
unfortunately, i still cannot login when prime-select nvidia
Please create a new nvidia-bug-report.log and attach. Since the last time the Xorg logs weren’t included, please also run
sudo journalctl -b0 --no-pager _COMM=gdm-x-session >journal.txt
after trying to log in and attach the output file.
Hello, I have the same issue, I tried the steps given above but it didn’t work. After reboot, the system cannot load graphics drivers and asked to run low graphic mode.
Can you help me please ? nvidia-bug-report.log.gz (2.55 MB)
This will leave graphics as-is and only install the kernel driver needed for cuda.
Afterwards, install cuda after downloading and adding the repo with
sudo apt install cuda-toolkit-10-1
